Driver's Seat??
Thanks!
1. move the seat into a position where you can remove the plastic cover over where the seatbelt bolts on to the seat frame. I was able to remove it with no tools by simply pulling the top of the piece gently towards the door opening and it will begin to unsnap.
2. Move the seat all the way forward and remove the 2 bolts holding the seat frame to the floor.
3. Move the seat all the way back and remove the 2 bolts holding the seat frame to the floor.
4. Make sure you lower the head rest all the way down and position the seat around the middle of the track. This will make it easier to remove the seat from the vehicle.
5. Un-do the battery and wait a few minutes. If the battery is left connected you may end up with "SRS Fault" and you will be making a trip to the dealer to reset this.
6. Lean the seat back against the rear seat and remove the cable connections.
7. Remove the seat.
8. Lay the seat down flat on the back and you will find 2 torx bolts holding on 2 U shaped clamps. Once these are off and the seat heater plug is removed from the holder, you can remove the entire bottom fo the seat, foam and all.
9. You dont need any tools to remove the old cover or to put on the new cover, just strong fingers.
On a side note, I did it exactly this way. I may have been able to just remove the 2 torx bolts and the U shaped clamps and taken the seat bottom off of the frame without doing all the other steps but I couldnt tell how it all came apart due to the lack of space and seeing what was under there. Im sure with the right torx socket it would be possible. It was 2 hours total but if you could just undo the 2 bolts and the U clamps, it would have been 20 minutes tops.
Im glad the seat now looks brand new and I saved myself the 3 hours the dealer quoted me on changing it for me.
Maybe add this to the "How to" section??
It looks like a computer/hard drive type connector (sorry, I don't know what this type of connection is actually called), but the wire connected to the seat is joined with another wire at the harness end (all the connections under the seat). IMPORTANT...you HAVE to remove both connectors together as one (there is a black connector, which is tied to the seat bottom, and another connector with a white end). I tried forever to remove the connector that was associated with the seat bottom only, and it would not budge at all. I finally realized that the connectors had to come out together (they are joined at the side with a notch). When you are ready to put the seat bottom back in, stick the connectors back together, and plug them in together.
It really is an easy process. You can remove the seat bottom in about 5 minutes, and reinstall in the same amount of time.
That said, and if you are only cleaning under the seat, I don't see the need to disconnect the seat wire harness.
If you have heated seats, that too is wired into the cushion (but I am sure you figured this part out when replacing the driver seat)...
So whether you are only replacing the MBTex or Leather cover (#27 in the chart below), or whether you are replacing the cover (#27) plus the cushion (#22) plus the bottom frame (#19) then you may still need to remove all 4 bolts holding the seat assembly onto the floorboard, tilt the seat back to allow yourself the ability to see what you are doing.
Good luck!
7. Remove the seat.
