Continental Tires dead in < 10K Miles
'08 C300 4Matic Sport, '02 530i
I have looked into the warranty and it looks promising. I just have not had the time to do anything about it. Here is the pamphlet. If the link doesn't work, go to continentaltire dot com -> customer FAQ (on left) -> Continental Tire Original Equipment Tire Warranty (1st link in "customer top answers")
continentaltire.custhelp.com/ci/fattach/get/4778/0/filename/Original+Equipment+Limited+Warranty
I would think OEM tires should have some warranty and that less than 10,000 miles is not normal.
Other than short life, I actually didn't think the CPCs were that bad.
If you want longer treadlife, find yourself a grand touring all-season tire (aka grandma tire) with the highest possible treadwear index and longest treadwear warranty. However, they only honor half that warranty length on cars with staggered setups like yours.
12K with the stock tires (Contis 225/45/17) for my '12 C300 and the tires still look quite good. It wore away about 3/32" so far (measured during last month's tire rotation). I guess driving habit is also an important factor.
I was actually hoping that the wear could be a bit faster so that I can go to Michelin Primacy MXM4.
We have 13K miles on our DWS currently and they have plenty of tread still left. I expect them to make it to 25K miles or more.
2009 C300 4Matic Sport + Premium 2
It's not as much about time as it is about the actual miles/kilometers driven. As you can imagine, two people could use the same tires for 7 months and during that time one will accumulate 3K miles while the other will accumulate 30K miles. So, which one are you?
#32
2015 ML350 Black/Black
Pretty much exactly what I think about most touring all-season tires ... great explanation!
#34
Conti DWS are Ultra High Performance all-seasons. However, due to the fact that they utilize winter rubber compounds, I find their steering response rather sloppy, unlike any other UHP all-season tire I've tried. I actually think the OEM ContiProContact provided better steering response than DWS.
#35
Haha... I used to own an Accord once with Energy MXV4 tires, which I think are even less performance oriented than MXM4. The traction and handling on these tires was abysmal, and worst of all, they just would not die. They seemed to last forever. That's the worst scenario I can think of on a sporty car (not that the Accord was one): being stuck with awful tires that just won't wear out and you feel bad about replacing them because so much tread is still left. Nowadays, I don't even wait for tires to wear out if I'm not happy with them. I sell them on craigslist to help offset the price of new ones.
#36
- Pilot MXM4
- Pilot HX MXM4
- Primacy MXM4
Primacy MXM4 is actually soft and is more comfort oriented. It is probably "boring" to most of performance-oriented drivers though.
#37
Thanks. I'll follow-up with them. But as someone else mentioned, I don't know that that says anything about tread warranty but rather what they deem as factory defects.
Same problem, 2011 C350 with conti's near the wear bar at just around 12,000 miles. I have looked into the warranty and it looks promising. I just have not had the time to do anything about it. Here is the pamphlet. If the link doesn't work, go to continentaltire dot com -> customer FAQ (on left) -> Continental Tire Original Equipment Tire Warranty (1st link in "customer top answers")
These things are terrible...to think with a 33month lease @10k per year I would have to be responsible for a set of tires is a little nuts.
#38
Any lasting long tires normally made with harder/stuffier compound. They are much worse on handling and traction but maybe good roll over. I drove MXM4 on my former Passat, possibly worse all seasons I know and yes they are last long. If you like Michelin all seasons take Pilot Sport A/S.... Anyway I am driving summer/winter tires sets with rims, highly recommended setup.
#39
Thanks again all for the comments. I guess it's just the way it is (assuming I do find that I have no alignment/suspension issue).
Just wanted to check being that I've never experienced such fast tire wear on a family car. Now I know...
#40
When you have your alignment done, you could ask them to bring the camber closer to zero. Your handling at the limits may get slightly worse as a result, but most average/non-aggressive drivers won't notice. The benefit is that the rears will wear more evenly and should last a bit longer.
#41
Right, that is what grandma need on her 1978 Buick ...
#42
I am not an aggressive driver and comfort is a very important factor for me. I used to have Primacy MXM4 on an A4 (ex car) and the ride was quiet and comfortable. Primacy MXM4 also gets good recommendation from E class forums.
I understand that using summer/winter tires is a better setup. But I would like to avoid changing tires.
#44
I would definitely check your alignment or alter your driving style. I have 17K miles on my OEM Continental's for the C350 Coupe and they have at least 80% of their tread.
I used Continental Extreme DWS on my BMW 128i for 20K miles and they were also in good shape. So, I don't think you are going to find a tire that wears significantly different.
300, c300, class, conticross, continental, continentals, glk, lasting, longest, mercedes, miles, pittsburgh, siteorg, tires, tyres
