Transmission Flush
Old Mar 31, 2013 | 11:17 AM
comanche's Avatar
Transmission Flush
Is it required? what are the benefits from having it done? My C300 is at 56K miles now, what else do you guys suggest to get done at this mileage?
The rear break pads are at 8 mm, when should I have them replaced?
Old Mar 31, 2013 | 01:08 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
I think it is every 40 k miles, but best to be sure and use the search function on the whole W204 thread.
Go "advanced" and put "Glyn Ruck" as the author. Key words are [ transmission oil change torque converter ]
BTW:
Just a little reminder about setting up your user cp:
___________________ *** All Members, New and some Old *** _______________
Please click on User CP at the top black band on the page, just below the thread title. Click Edit Your Details to provide your location: city & state, and non-US country if applicable. Then click Signature, and add year, model(Hatch?), 6S or 6i, and mods as others have done.
This helps others respond to issues & problems, like tires, part sales, troubleshooting, etc. Thanx
Old Mar 31, 2013 | 07:00 PM
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
It is required every 40K miles. The benefit is that your trans won't die before you hit 100K miles.
When you get it done, make sure it's done correctly. This means draining the fluid not only from the trans itself but also from the torque converter area. Sadly, most dealers in the US only do half the job. It's covered in detail by one of the sticky threads on this forum. You might want to check it out.
When the brake sensor tells you to.
Old Apr 1, 2013 | 11:10 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The MBUSA dealers from everything I have heard/read absolutely do not drain the torque converter. This is a big mistake.
You need to get all the old fluid out and all new fluid in. My new-to-me 2011 C300 has just 11,800 miles but when it gets to 39,000 I will have it done properly. It is worth the extra expense for the peace of mind.
