Old Jun 8, 2015, 03:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
How to install Spoiler
Old Apr 23, 2013 | 11:40 PM
pranavf01's Avatar
2013 c250, 2009 BMW 750i, 2010 Honda Accord, 1950 Willys Jeep, 1955 Hindustan Landmaster
I recently purchased a painted amg style spoiler and i do not know how to install it. I bought this tape http://www.autozone.com/autozone/acc...er=517047_0_0_
would it be enough to hold it securely?
Thanks in advance.
Old Apr 24, 2013 | 02:44 AM
dolvio's Avatar
2010 C250 4Matic
Thanks in advance.
Use some 3M tape. Actually go to a local body shop and they willprobably give you some. Cheers.
Old Apr 24, 2013 | 02:49 AM
Cillys's Avatar
2011 C300 Sport 4MATIC
Make sure it is double sided too
Old Apr 24, 2013 | 12:18 PM
Sportstick's Avatar
Another round of ICE
Thanks in advance.
Possibly not. It is difficult to know and control for all variables including surface prep, surface temp, proper psi along length of spoiler as being applied, cure time, etc. I've had OE adhesives fail even with controlled applications in the plant on vehicle programs I worked on at a domestic car company. I strongly suggest using a bead of urethane along the tape, and blue tape to hold it in place for a day. Be sure it's in the right spot. This one wont easily come off. But, the guy on the highway behind you will be thankful.
Old Apr 24, 2013 | 01:26 PM
pranavf01's Avatar
Thank you all soo much for suggestions. I have never installed anything like this before, iam going to use the urethane to make it extra secure. It said on jbspeed.com that this would come with 3m tape on it, but when i got it it was not there. That is the reason I fell in a dilama about to drill holes or use tape.
Old Apr 24, 2013 | 07:58 PM
BrandonBenson's Avatar
2013 GL450
Just clean and dry the surface, you should not have a problem. Many manufacturers used the 3M trim tape to hold on spoilers and exterior trim.
Old Apr 24, 2013 | 09:00 PM
Sportstick's Avatar
....including the one for which I worked, and have occasionally seen them fall off, even when applied in controlled plant environments exactly according to the manufacturer spec. Bodyside moldings are one thing, but a head-height rear spoiler is quite another.
Old Apr 24, 2013 | 09:06 PM
caligreenzzz's Avatar
W204
its not that serious bro, all one needs is double sided 3M tape
Old Apr 24, 2013 | 09:11 PM
itsLoonie's Avatar
2012 E350 RWD
I used double sided tape by 3M. Has been on the car for over a year. Works enough for me
Old Apr 24, 2013 | 09:14 PM
Sportstick's Avatar
Sure, most work. Some don't. How much risk you want to take depends on how much you care about the possible effects of a failure. I can tell you from working around high volume production, this stuff is far from totally reliable even in "perfect" conditions. Make your own decisions from there.
Old Apr 24, 2013 | 09:18 PM
W204
