"Tire Pressure Monitor Inoperative"
all tire pressures are a-ok. car is an '09 C 63 with 2700 miles.
so, i can't reset it. it doesn't allow me to do it from the dash because it says it's inoperative. which leads me to believe it's not a sensor, but it's the receiver in the car. i'd like to hard reset it by pulling the fuse (actually i'd like to check the fuse first) but I HAVE NO IDEA HOW TO FIND OUT WHAT FUSE IS FOR THE TPMS SYSTEM!
where the heck are the fuse diagrams for all the fuse blocks??? i looked in all the books, i looked in the spare tire equipment...nothing.
so anyway it looks like it's position 70 in the rear (trunk) block.
here is an update: https://mbworld.org/forums/5632497-post7.html
Update: the fix worked. Apparently there is a ground issue where it invites interference which makes the control module freak out. They moved the ground, as well as shortened it.
