Water got in the fuse box, car is pretty bad
Still with the fuse cover off (stupid but i thought i'd let it dry out more with engine heat), I went for a drive to town, the only thing the car did was squirt washer fluid on the windshield every couple minutes and the wipers didnt work. Suddenly the wipers worked and everything was fine, but then the washer fluid went on and stayed on and it drained out the whole tank. The cluster started going crazy again! obviously because I stupidly left the fuse box cover off and the washer fluid got in it! I flew home (10 minute drive) with the cluster freaking out because I knew if I turned it off the car wouldn't start.
I dried everything thing out again, this time took apart the fuse panel plate and dried water out under their and this time when I put the battery on it was the same. After disconnecting the battery a couple times, sometimes its normal and then after 5 minutes of running it goes back to its error messages.
I waited a couple days with the battery disconnected and this morning reconnected it. It was totally normal for the first five minutes of running, but then went into its whole error routine. I figured out this morning that it wasn't only because I left my fuse box cover off, but because the drain holes for the water duct under the windshield was clogged, water was literally draining right into the fuse box.
here are videos of the problems:
Does anyone have any idea what I need to replace to fix this? the front SAM? I noticed a logic board in the fuse box, the whole fuse box assembly? I really hope I don't have to replace each and every component that isn't working (ESP, cruise control, cluster etc. )
the good thing is the car runs perfectly fine so its not the ecu or anything like that.
any help would be appreciated!
If you do not wish to go to MB service, who can (if they are competent) through looking at error codes perhaps pinpoint the source of the fault. Most wrecked exotic rebuild specialists have experience in solving these problems as a front end collision usually damages the fusebox area, being located just behind the front fender.
Cost me a well-spent $1k DLS, also this shop removed an aftermarket alarm system which had been terribly installed and was the cause of constant battery discharge. The original manufacturer agency quoted about $13k DLS as they wanted to replace the entire wiring harness.
Have you taken the whole thing out of the car? I would do that. I would take it all out, take as much of it apart as possible. Clean all the connections and make sure it is dry.
You should not have to replace other things like the ESP module or anything.
In a single drive the headlights will go from being stuck on all the time to working normally. When they are stuck on all the time the light switch is useless and you can't turn on the fogs or anything. Also when you unlock the car at night the lights do not come on. While driving it literally switches from good to bad, so during the day the headlights will be going on and off.
Also,
the switches under the radio for the heated seats and rear sunshade don't work and lately the ESP off and hazard switch doesn't work. At night all the interior illumination is okay except for the illumination behind these buttons, with the passenger airbag off light the illumination literally flickers on and off, real weird. There was also a point when I could get the heated seats to work by holding the button for like 7 seconds.
This is obviously a result of water getting into the fuse box. Nothing else happened to the car. Do you think I could get the SAM in the fuse box reprogrammed to fix this? Or are there deeper problems then that?
This is the last thing I ever thought would of happened to my prized possession. I hate chasing electoral gremlins and am hoping one SAM reprogramming or replacement will fix this!
