c350 lcd removal
Old May 21, 2013 | 06:48 PM
Chopper63d's Avatar
2008 c350
c350 lcd removal
ok so my screen of course has the black screen syndrome.... now I want to replace the LCD screen or at least see if I can repair it. I have the comand screen out of the dash, but does anyone know how to remove the actual screen?
Old May 21, 2013 | 11:09 PM
fazooley's Avatar
2013 w204 C350
Send me a PM with your email address and I'll send you the ALLDATA removal instructions.
Frankie
Old May 22, 2013 | 07:18 PM
Chopper63d's Avatar
2008 c350
PM sent.. thanks again
Old May 25, 2013 | 08:52 PM
Chopper63d's Avatar
2008 c350
bump
Old May 26, 2013 | 04:05 AM
vic viper's Avatar
S213
check with this seller, he might have installation instructions:
http://www.ebay.com/itm/LG-7-LCD-TFT-Display-Mercedes-Benz-W204-X204-C-class-GLK-class-NTG4-comand-/290896090008?pt=LH_DefaultDomain_0&hash=item43bac21398
Old May 29, 2013 | 11:59 AM
Chopper63d's Avatar
2008 c350
seller never replied
bump!
Old Jun 4, 2013 | 05:04 PM
Chopper63d's Avatar
2008 c350
bump
Old Jun 9, 2013 | 12:11 PM
nigel_91's Avatar
slk350 r171
Frankie
hi. could you do the same for me as well. regards nigel
Old Jun 25, 2013 | 07:47 PM
Chopper63d's Avatar
2008 c350
bump
Old Jul 14, 2013 | 02:37 PM
Chopper63d's Avatar
2008 c350
bump
Old Jul 18, 2013 | 05:41 PM
Chopper63d's Avatar
2008 c350
Okay so i went ahead and did it on my own. I fix the screen problem. Might not be the best way of repairing it but it works so far.
On the very corner of the screen you can see where its burnt. Seems like it overheat and melted the wire. I went ahead and took apart the actual screen and notice that on the very edge is uses bulbs to light up the screen. Found out that the light werent turning on and was why the screen wouldnt lite up. I went ahead and solder the wire back together to the bulb and the screen worked again.
Old Jul 18, 2013 | 05:46 PM
Chopper63d's Avatar
2008 c350
I realize after i should of took more pictures so i can do a DIY but i put the screen back on the car cause i was over joy that i didnt have to spend more then 200$ to get it fixed. So you need help please PM me or Email chopper63d@gmail.com.
