Serious Blackberry Issues
Old May 30, 2013 | 04:09 AM
dolvio's Avatar
2010 C250 4Matic
I realize there are a few threads on this but my specific situation is different.
I have a corporate Blackberry Bold 9900. I spend a lot of time in my car and using my phone and having a Bluetooth is an absolute must as it is illegal here to even look at your phone while driving.
I have had a lot of issues connecting my phone to work properly. For the last few weeks it wouldn't connect. I tried it again yesterday and it worked perfectly... I was thrilled. This morning there are new problems. When the car connects to the phone the car starts ringing and says I have an incoming call. I reject, car still rings and rings until I disconnect the Bluetooth connection on the phone. Try it again same thing. It's absolutely nuts.
Went to dealer and they said it's the phone. My phone is newish and I have never had a problem even on my old 2006 G35. I am so choked about this as need this to work.
I have tried pairing over and over also...
Thoughts or help...?
Old May 30, 2013 | 04:32 AM
vic viper's Avatar
S213
Seems like a common problem:
Found this:
"07-11-2012 09:48 PM
Finally a fix. I can't take credit for it. I saw the answer in another forum
Unpaired the devices
Under bluetooth connections press the menu/blackberry key
Then optiions
The only thing I have checked is
Led connection indicator
Headset
And handsfree
Note that encryption and connect on power up are un checked
Also at first I only had headset checked. I enabled handsfree after I paired so I could use voice commands."
Old May 31, 2013 | 05:07 PM
Logic10's Avatar
C350 4Matic Coupe
I have a Blackberry z10 and have had no problems connecting, phoning, or even reading text messages with a 2013 C350. Perhaps you can change that blackberry out for a new z10 or q10 - both have the new operating system and are a real treat to use.
Old Jun 23, 2013 | 10:45 AM
caligreenzzz's Avatar
W204
Dam they still make blackberries.........upgrade ur phone
Old Jun 23, 2013 | 11:14 AM
dolvio's Avatar
2010 C250 4Matic
You do know what corporte means right you retard?
Old Jun 23, 2013 | 02:37 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I just tried to google that word because i don't know what it means.
Would you please enlighten us.
TY
Old Jun 23, 2013 | 02:41 PM
dolvio's Avatar
2010 C250 4Matic
If you actually had to google that and try to figure it out you must spend less time circle jerking wirh caligreenzzz. Get a life man. Seriously. Get laid or something.
