Quick Door Pin Q...?
1 Post
2010 C250 4Matic
Guys,
Swapped out the door pins today. Easy but the Front Passenger needed a wrench to get it on as elbow grease just wasn't working. Done though.
The rears. We all know it is a pain. I began looking at taking the door panel off to get them done properly. Checked online and reviewed the threads. Does anyone have an actual step by step or could post a video??
Much appreciated,
Adam
Much appreciated,
Adam
1 Post
2010 C250 4Matic
I think I was able to find it. I read one.. I was having trouble tonight getting enough grip to pull the panel off. Took out the two bolts and tried to wedge a putty knife in. Scared a little honestly...
You have to take apart the door to replace the pins?? damn, I thought it was just a simple unscrew/rescrew and was looking for a set that sat flush when locked. I like to rest my arm on the door and the stock pin is always poking me.
Rear-No
The rear are a type of friction/Ball & Socket mount. Honestly- Stupid design.
The top edge of the door hangs over a lip. Start pulling from the bottom and it will be easier.
1 Post
2010 C250 4Matic
1 Post
2010 C250 4Matic
Would you mind giving me an idea on where to start pulling and how to get the panel off to a good start...? do the panels go back on just as tight also? I may actually have the dealer do this...
2009 C300 4Matic Sport
Once you get eyes on the door pin assembly it will make sense what you need to do. There is a clip attachment that secures the upper "pin guide" to the main pin holding portion. This, I believe, is what others have broken by pushing down too hard when installing from above w/o removing the panel. If you unclip the attachement, the you have free rain to pull, push, pry, etc the door pin out and then insert the new one.
Hopefully this helps.
