problem with DC on my w204
Old Jun 22, 2013 | 09:22 AM
nos09's Avatar
c220 CDI w204
i have problem with DC after installing my new audiosystem on my car..
i install pioneer avh x8500bt.. the drifts looks ok when i checked them with the multimeter and also the the system works fine.
when i lock the door after some hours, i unlock the car put the key on to start the system and i realized that it lost the channels from the memory..
CAN ANYONE TO HELP ME!!!
Old Jun 22, 2013 | 05:30 PM
Acapulco Bill's Avatar
2010 C300 Sport
Sounds like the Pioneer unit doesnt store information in a flash memory, but in a powered RAM memory which loses its data when power is turned off.
Test the Pioneer first by turning it off, then on while the car is running, to make sure that the memory doesnt lose its stored information. If you lose the data just turning off the Pioneer unit while the engine is running, then the unit itself is defective.
A solution is to hook the +12 v. to an always-live voltage source such as the cigarette lighter. The disadvantage is that you will have to always turn off the unit manually to keep from running the battery down. Sounds like unintelligent Pioneer engineering, that the data erases when the car is turned off.
Old Jun 22, 2013 | 08:02 PM
got_thang?'s Avatar
2008 C350
I replied to your pm. Run it to your battery reason because the car shuts all accessory power after the car sits for a while. it's not a defective unit. I know because I ran 3 headunits before they all had the same problem
Old Jun 23, 2013 | 08:18 AM
nos09's Avatar
c220 CDI w204
thanks for your replies
