Rear View Camera (yes I did a search first)
Yep I have comand ntg 4.5, the interface I bought is just malfunctioning. I tried it on my test bench and its definitely not working. I will post back when I receive the second module I ordered from car solutions.
No idea. When I pulled the headunit out it says comand ntg 4.5 on it. I checked in the back and there's no fakra connections available it already has something plugged in both ports. My car has the harman kardon logic 7 in it, no nav but has multimedia interface in the center console, no hard drive built in either. In the engineering menu it has no option for rear camera and the menu is different than others I've seen.
Is this a 2012 thing or what? It's a c250 sport.
So I contacted xcarlink and was told that the unit won't stay on if there's no can low/high signal. Checked the "plug and play" harness and of course some of the wires including the can low and high don't match my cars harness. Re wired the can cables to match those on my original harness and bingo, the interface stays on and works now.
The colors were different on my harness to what their manual says. Also on the interface there's an aux l and aux r coming out I'm guessing for those with aux input, I had to cut those because they matched to the wrong cables onu my car'a harness and was shorting out the screen.
Just need to wire the camera and run the video cable to the trunk, while I did this also left a second video cable wired to the interface for my iPhone in the future.
If anyone's wondering wiring this interface behind the monitor and routing the cables was for me pretty difficult and I don't really recommend anyone doing it unless they know what they're doing.
#32
2012 C250 Sedan
Recap and verification
OK.
Thank you to everyone who is helping me by participating in this thread.
Just to review I have the small screen and no navigation system. I believe I have the A20. I have uploaded images of the engineering menu before but here is the front panel where radio and CD player is.
Now can someone please confirm for me what equipment that has been discussed here is most suited to my little C250 or is it just not possible.
I would prefer to use the existing screen and not add one.
Thanks again.
Scott
Thanks again.
Scott
#33
OK.
Thanks again.
Scott
Thanks again.
Scott
#34
So here's a new learning from the COMAND engineering menu, for me anyway. When you enable the video you get the video feed. I've seen that you use SRVC as the option. When this is used, there is also a SRVC Guidelines that can be enabled. These are the guidelines for the camera when the car is put in reverse.
Now all I have to do is get me camera hooked up. Cheers.
#35
2013 C250 - Lunar Blue
What do you mean "When you enable the video you get the video feed"? Are you saying that if I pug a camera into my head unit and turn it on, I will get the video on my screen?
Thanks,
Gus
#36
I have a 2010 with the flip up screen (not sure which this is) with the iPod cable in the glove box. You have to disconnect the video side of this cable at the back of the head unit and plug in the camera using one of the Fakra adapters sold on eBay or Amazon. Then when you enable video in the engineering menu, yes, you will have a backup camera. It costs me a total of roughly $60 US. I've listed the items with a pic in one of my earlier posts on the subject.
Good luck!
Good luck!
#37
Veyron VI-MBC Installation Problems
Hi
The Veyron Module do not work yet. Installation is done, but there is no picture
yet. The green lights do not stay on after connecting the power/CAN+/CAN- plug to the black Interface box. They turn off after 2 secons. Is that normal?
How to wake up the screen? Shall the green loose wire 12V be connected to camera Power+ before the first test?
My modem unit is the same as photo from Doa.
Model MB E200 GC1 Elegance W212 10/2011.
Can I get help please...![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Br, Ian
Br, Ian
