2008 C63 comand reboots on door opening and on ignition off
I wonder if anyone around here ever experienced this before. 2008 C63 LCD is up, comand is working and without any reason if any doors are opened or ignition is swtched off/on the unit reboots itself. Any clues? Workarounds? TIA
This is usually caused by problems with the MOST loop circuit, you can go into engineering mode to check if any settings have changed, if you donīt have 810 sound system (h/k) this also need to be unchecked in the HU as the sound system uses the MOST bus for communication.
Viper, do you mind sharing your MOST parameters here? I have no information as far as H/K goes other than my car is fully loaded with optionals and sound quality is nothing more than superb. But no H/K logo on the grills ...
But I do remember me messing around engineering menu and changing the MOST setting. Problem was I didn't keep a note on the defaults and reset didn't bring it up back to normal. Other than this, I now see a BT antenna open and FM antenna Open. So Weird ...
