Wheel Center Bore??
Old Jul 26, 2013 | 11:02 PM
Mr.Fugge's Avatar
C300
Wheel Center Bore??
So to start with I did search but came up with nothing. In advance I'm sorry if this has been talked about many times.
Wheels I'm interested in specs:
Front Wheels: 19" x 8.5"
Rear Wheels: 19" x 9.5"
Bolt Pattern: 5x112
Front Offset: 42 ET
Rear Offset: 42 ET
Center Bore: 72.56
w204 Center Bore is 66.6.
Could this still work if the center bore is 72.56??
Thank Yyou for your time.
Old Jul 27, 2013 | 05:05 AM
vic viper's Avatar
S213
All you need is a ring spacer, 66.6mm inner and 72.6mm outer diameter, however ET42 in the rear with a 9.5" wheel could be a tight fit, ET50 would be a lot better.
