Diagnostic tool question
Old Aug 3, 2013 | 10:28 AM
bobven's Avatar
C 200 CGI
Question Diagnostic tool question
Friends,
I would like to know if the OBD2 scanners be able to pick up the vehicle past data such as mileage clocked or tampered kinda thing?
Which one is the best OBD2 scanner for C200 CGI ?
Advise appreciated...
Old Aug 3, 2013 | 07:55 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Originally Posted by bobven
Friends,
I could not be sure but I doubt that the scanner will give you mileage & whether it has been wound back or not.
I bought my scanner on Ebay. They vary in price depending on their features eg fault codes given as numbers or text. Mine is a Autel MaxiDigag EU702 bought a few years ago for between $200 -$300 .
The main thing is to make sure the scanner is compatible with your car. The advertising should specify this. eg OBD11 compliant European Brand vehicles including Can Bus. MB 1995 to 2006.
Some people have two, a small cheap on for in the car & another one for the workshop.
Old Aug 3, 2013 | 11:34 PM
Acapulco Bill's Avatar
2010 C300 Sport
snowmuch's thread show a photo of Torque Pro running off a Bluetooth OBDII scanner. You may want to ask him directly how much info he actually gets from the scanner.
https://mbworld.org/forums/c-class-w...-solution.html
Using this OBDII scanner on my M3 (in another country) and it works fabulously, and a smartphone can retransmit the screen, as snowmuch has done, onto the aftermarket 8" nav system. Looks great, shows important codes, like the vanos (variable camshaft timing in BMW-speak) module is becoming unsoldered, which causes massive M3 engine failures.
Here is an Amazon link:
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
