39k Trans Service Adventure Begins
All opinion states that a flush should be done every 39,000 miles.
Why compromise the long term wellbeing of your transmission with only having a drain & paying a few bucks less.
Surely there is an experienced workshop relatively handy that will do the correct job .
I would cancel the appointment & go elsewhere as your dealer does not have the willingness , technical ability, equipment & tools to do the job.
Spoke to local dealership after dropping car off yesterday. SA indicated there was ABSOLUTELY no drain plug on TC and then verified that with the shop foreman. BUT, SA indicated they would look into it further once they had the car on the lift. Left dealership thinking this was just customer "servicing", but wanted to give them a chance to make the situation right and then I would formulate next steps.
Today SA calls and said that my car does have a drain on the TC and they drained it, and they will need to charge for a few additional units of fluid--indicated no problem with that as I just wanted all the fluid changed. Additionally, I reported the "soft shift" between 2-3 on warmup that occurs occasionally. SA indicated they updated the tranny software and they believe that will address the concern. We will see.
SA mentioned that my tranny has blue fluid and that all did after a certain point in 2010, I believe. I was under the impression that the blue fluid was only for the 7G Plus with start/stop? Any comments?
