Swapping AMG 18"mags
Old Aug 29, 2013 | 02:53 AM
QuadB4's Avatar
2013 Mercedes C200 // 2010 Mercedes E300
Swapping E Class AMG 18" rims to C class 17" stock rims
Hi everybody. Newbie here. I would just like to ask if anybody knows if it is possible to interchange wheels from my E Class 2010 (AMG rims 18") into my C class 2013 (17" rims stock). Any fitment issue? Please help, I wanted to set up my C Class same as with others having here. I know this is the right place to ask..
Old Aug 29, 2013 | 06:58 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Welcome to the forums!
Can you tell us the specs on the E Class wheels? width, diameter and offset? The 5/112 bolt pattern will allow them to be bolted on but offset may be the sticking point.
Of note: "Mag" wheels are the old hot rodders magnesium wheels....very light, kinda brittle, almost never seen any more....and "Rims" are the outside portion of the wheel....
Old Aug 31, 2013 | 03:06 PM
QuadB4's Avatar
235/40/18 in the front and
255/35/18 in the rear
I dont know the offsets.Do you think I could get these to run?
Old Aug 31, 2013 | 09:48 PM
bobblehead's Avatar
go fast grocery getter wagon
Your E class 18" AMG style wheels
Front : 18x8" ET45
Rear : 18x8.5" ET49
For C class 18" AMG style wheels
Front : 18x8" ET50
Rear : 18x8.5" ET54
F & R: +5mm clearance from strut and +5mm extension outward
Therefore, no issue at all.
Old Sep 2, 2013 | 03:02 AM
Matt-erhorn's Avatar
2015 C250 Coupe
E class wheels fit fine on the C class, I have the MBSport wheels for the W212 on mine and get no rub and no issues at all. See sig for pic of the wheels.
Old Sep 4, 2013 | 03:33 AM
QuadB4's Avatar
Thanks for your advice. Is it also okay to put the stock C class 17" rims to E class?
Old Sep 4, 2013 | 03:37 AM
QuadB4's Avatar
Thanks Matt. You have a nice mods and clean ride. We have the same polar white color, and I would probably do the same in my C.
Old Sep 4, 2013 | 06:58 PM
joespeed29's Avatar
2013 C300 Sport
Lol mags
Old Feb 13, 2014 | 10:38 AM
Fonda689's Avatar
2011 c300 4matic w204
Hey guys. I'm very new to this.
I have a 2011 c300 4 matic
Just purchases these mags and I have no idea if they fit.
PLEASE HELP !!!!
Specs
Front
18x7.5 et37 with 225/45/18
Rear
18x8.5 et30 with 245/40/18
Please help. Want to make them fit.
Old Feb 13, 2014 | 11:12 AM
xaran's Avatar
2012 C 250 Sport Sedan
PLEASE HELP !!!!
Specs
Front
Rear
They do not have enough offset, your C class rims are about 48 fnt and 55 rear the rims you have will be sticking out 10+ mm fnt and 25mm rear . They will probably rub the fenders and not look correct for the car. Also the tire sizes are + size over stock so they will be taller.
You can get away with 45 off set all around in 17-18-19" rims and 7.5-8.5 wide but IMO the rear look better with a little more offset 48 -55 in the rear. With the tires in 18" to maintain stock profile you need 225-40-18 and a 255-35-18 rear or a 265-35-18 rear to fit.
Old Feb 13, 2014 | 11:20 AM
Fonda689's Avatar
Wow. Ok. Thanks for that advice. Any other way this can get done. Really really like the look if these mags.
Old Feb 13, 2014 | 11:24 AM
xaran's Avatar
No way. If you have too much offset you can add spacers to move the wheel out but if you have too little offset (your case) you can not move them in to the wheel well. Your rear wheels are 25 mm out that is almost 1" that is a lot and will rub. Especially if you add those taller tires, it will also slow acceleration and throw off the speedo
The C Class W 204 need a lot more offset than most cars . Most of the 30 -40 off set wheels are set up for Front Wheel drive cars
Old Feb 13, 2014 | 12:13 PM
Fonda689's Avatar
For sale
Check add
5x112 18" mags amg Mercedes Benz MB on Kijiji http://montreal.kijiji.ca/c-ViewAd?AdId=566756054
Price is negotiable.
