Blacking Out Headlight Issue
Old Sep 9, 2013 | 10:01 AM
Chuey's Avatar
C300
Alright so over the weekend I attempted to do this mod and it could've went a bit better. Overall it looks decent, but not perfect. I didn't tape as good as I thought I did so there was some leakage here and there and I was wondering if paint remover should be used on these areas. The most annoying being the reflective area for the turn signal and the clear portion at the front of the projectors. Also can the chrome part of the bixenon bezel be removed to paint? Taping off everything was a complete pain. Thanks
Old Sep 9, 2013 | 06:01 PM
Chuey's Avatar
C300
Someone helppp!!!!
Old Sep 9, 2013 | 06:31 PM
C230Kompressed's Avatar
I drive what I drive
Removing paint from plastic is tricky. You can't use normal paint thinner/remover or else it will make the plastic corrode.
Check out this link for a good answer I found on google:
http://ecomodder.com/forum/showthrea...tic-20012.html
