Old Jun 9, 2015, 02:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Change audio20 speakers.
Old Sep 29, 2013 | 11:59 AM
n3cr1d's Avatar
w204
Hey dudes,
I want to change default speakers (audio 20 no HK) to others. The HK tweeters is the only thing i changed in my audio.
Reading in this forum i found many solutions. There are my questions:
1- To front speakers the best are Kappa 60.9?
http://www.ebay.com/itm/INFINITY-KAPPA-60-9CS-CAR-AUDIO-2-WAY-6-5-COMPONENT-SPEAKER-SYSTEM-SET-6-1-2-/331031628286?pt=Car_Speakers&hash=item4d1305c9fe
2- And to rear speakers the best are Kappa 6032Si?
http://www.ebay.com/itm/Infinity-Reference-6032Si-Full-Range-6-5-Coaxial-Car-Speakers-2-Way-150W-New-/130968794931?pt=Car_Speakers&hash=item1e7e593733
3-The instalation will be easy? Just change the original for Kappa?
4- And EQ settings? I tryed to change, but when i back to Eng Menu the settings are default
5- I read somewhere if you press back+central controller+clear will open a menu to change diferent volumes. I tryed this and nothing happens. What can i do ?
Nice sunday.
Nik
Old Sep 29, 2013 | 06:38 PM
SoCal208's Avatar
12E350, 12ML350, 08C350
Originally Posted by n3cr1d
Hey dudes,
Infinity Kappa 60 9CS Car Audio 2 Way 6 5" Component Speaker System Set 6 1 2" 50667110130 | eBay
Infinity® Reference 6032SI Full Range 6 5” Coaxial Car Speakers 2 Way 150W New 050667110291 | eBay
Nice sunday.
Nik
I replaced the same Infinity Kappa speakers on my C350 (audio 20). The local car's stereo shop replaced for $120 (have to take all the door panel to get access to the speakers, that's too much for me, beside the tweeters have to solder to the wiring). Search for W204 speakers upgrade, Acapulco Bill have some useful advice. I am really happy with the speakers update, It sound way much better than the stock speakers. Be sure to tie wrap the equalizer on the front + set it to 0 (not 16) to void the rattle. I bought the speakers from Amazon (a little less than flebay) with free shipping. Report back what will you do. Good luck.
Old Sep 29, 2013 | 06:53 PM
n3cr1d's Avatar
w204
Thanks for info socal.
"Be sure to tie wrap the equalizer on the front + set it to 0 (not 16) to void the rattle.
I dont understand this. When you say to equalizer to 0 not 16 is in the engenier menu? How i do it?
Thanks again.
Nik
Old Sep 30, 2013 | 05:11 PM
KCaudell's Avatar
2016 C300 4Matic Sport
I found the Infinity tweeters WAY to bright. I replaced them with the Alpine SPS-110TW and they are much more pleasant. The speakers that you reference will fit. Follow SoCal's advice and read the thread on this install. You'll need to cut out the existing speakers that are SO CHEAP it's shocking (and disappointing), plastic frame and all. The Alpine and Infinity tweeters will fit into the stock holder on the front door frame with a little ingenuity.
Old Sep 30, 2013 | 09:31 PM
SoCal208's Avatar
Thanks again.
Nik
Hello,
On the equalizer, there is a button to adjust (from 0 to 16), leave it @ 0 (I got this advice from Acapulco Bill). Regards.
Old Oct 16, 2013 | 07:20 PM
C0d3Sp4c3's Avatar
2013 C250
I think what I have is the famous Audio 20. I read somewhere that I should be able to access the EQ settings by holding down "Hang up" button on the steering, 1 & # at the same time. Done that many times but not successful. What I have is just Trebble, Bass & Fader settings but no EQ. Am I missing something or I do not have the EQ settings.
Old Sep 21, 2015 | 03:26 PM
Sunny18's Avatar
Mercedes e class, bmw 330i, Audi A6
HK sound upgrade
Hey I have a 2014 e class w212 facelift with stock speakers (audio 20). I wish to upgrade my car's door speakers and tweeters to harman kardon speakers. I don't want to add an amplifier. I just want to swap the speakers and tweeters. Will I be able to tell a difference.
