Front strut spring question
Old Dec 17, 2013 | 09:44 AM
Norm01's Avatar
2011 E550 Coupe
I removed my H&R SuperSports from my car and reinstalled the OEM springs. The issue I had was I cannot tell which way the spring goes and if it would make a difference. Both ends of the spring seem quite similar. The only markings on the spring are a colour code combination. The way I installed them is with the colour code up and the spring sat nicely in the bottom perch against the stop. Does anyone know a definitive answer if there is a right and wrong way to these. Thanks.
Old Dec 18, 2013 | 12:19 PM
Norm01's Avatar
2011 E550 Coupe
Still looking to see if an MB Tech can help me out with this.
Old Dec 18, 2013 | 12:29 PM
vic viper's Avatar
S213
Depends on the spring, some springs have a larger end and some are the same on both ends, just make sure the spring have a snug fit on the rubber mount on the strut bearing and you´ll be fine.
Old Dec 18, 2013 | 01:11 PM
Norm01's Avatar
2011 E550 Coupe
Thanks Johan, much appreciated. Both top and bottom plates fit snugly.
