Tail light issue (pics included)
Hey guys,
I got pulled over on New Years Eve the other day for my right side brake light not working.
I checked it out, and it turns out it was actually the right side parking light (you know the one when you pull the lights *** out 2 times to turn them on).
I went and bought two new bulbs (Sylvania 7506 LL). I took off the light bulb holder and noticed when I was taking it out the light was on but just dimmed really low. I replaced it, and it was still putting out a very low dim.
Is it suppose to be like that? Or is it a electrical error? My warranty covers anything that isn't wear and tear basically (oil change, brake change, light bulbs, etc) but if it's a more serious problem then I can take it to the dealer for repair. (unfortunately it would probably take them at least a month to do, terrible service)
What do you guys think? Here are some pics...
Left Side
![Tail light issue (pics included)-eovtkjd.jpg](https://mbworld.org/forums/attachments/c-class-w204/447286d1683253800t-tail-light-issue-pics-included-eovtkjd.jpg)
![Tail light issue (pics included)-zsfjjbe.jpg](https://mbworld.org/forums/attachments/c-class-w204/447287d1683253800t-tail-light-issue-pics-included-zsfjjbe.jpg)
Right Side
![Tail light issue (pics included)-hskl9bo.jpg](https://mbworld.org/forums/attachments/c-class-w204/447288d1683253800t-tail-light-issue-pics-included-hskl9bo.jpg)
Left Side
Right Side
![Tail light issue (pics included)-psgdxne.jpg](https://mbworld.org/forums/attachments/c-class-w204/447289d1683253800t-tail-light-issue-pics-included-psgdxne.jpg)
So if it is due to a burn/melt, what would the next step be in order to repair it? Is it just a snip and re-splicing of a wire or does the entire bulb holder need to be replaced?
Lots of details and photos on the 2 or 3 other threads about this. Usually the bulb holder plate has a burn on it where the ground is attached. The bulb plates are actually surprisingly cheap. So a minimum repair is a new heavier gauge ground wire, new pin, maybe a new connector, and a new bulb plate - for each side.
