idling on cold weather...good or bad?
Old Jan 9, 2014 | 09:16 PM
MBSebas87's Avatar
C300 Sport 4Matic
So every morning I start up my C and let it idle for 5 min for the engine to warm up.....is this good for the engine? Read somewhere to just take off after start
Old Jan 9, 2014 | 09:38 PM
MDMercedesGuy's Avatar
2024 GLS450
It isn't efficient, and it doesn't help your engine warm up much. These engines are so efficient that they don't make much heat at idle.
The best thing for your car and for the environment is to start it up, let the idle equalize (15-20 seconds) and drive off. Keep it under light load until it gets up to operating temperature.
The ultimate goal is to get the vehicle warmed up to the point where it enters closed loop mode and is running at its most efficient state.
Old Jan 9, 2014 | 09:48 PM
w204_Generic's Avatar
2011 C300 4Matic Sport
What about once you reach you destination? Should you leave the car idling for about 3-5 minutes or so to let it "cool down," or will shutting it off immediately after putting it in park will do just fine?
Another question is what would be the optimum oil temperature, in which you can start driving you car a little more "aggressively," than gentle driving to reach the temperature? Keep in mind the quotes around aggressive.
Old Jan 9, 2014 | 10:31 PM
2024 GLS450
As far as idling down - I'd say only if you have been driving it hard. I have a turbo, so I do tend to idle down for 2 or so minutes if I have been sticking my foot in it a bunch. It's not really necessary any more with modern turbos, but I figure it can't hurt.
As far as oil temperature goes - that's a really good point. Engine coolant temp being up to full temp doesn't mean that oil temp is there yet. I don't have my scangauge any more - but I'd imagine 5 or 6 minutes after the coolant temp levels off the oil is good to go in these cars.
Not sure if the V6es are this way - but the 1.8 puts off so little waste heat if you aren't driving it hard that running the climate control severely impedes its ability to get the coolant temp to the point where it levels off if you are in stop and go traffic if it is cold out. In fact, during this latest cold snap my car wouldn't get over 80*C in a 25 mile highway drive with the cruise on and the interior climate control set to 68 for both sides - it was about 15*F out.
Old Jan 10, 2014 | 08:40 AM
spyked's Avatar
2026 GLC300 4Matic (X254)
Keep in mind...in many places it is also illegal. lMany people have received tickets over the last few days around here. So many that it's on the news. It's definitely bad for the environment in terms of wasted fuel and the worst kind of emissions.
But in terms of the car itself....it doesn't DAMAGE anything until you drive it like you stole it thinking it's "warm" when its really not. Idling doesn't warm anything but the atmosphere.
Old Jan 10, 2014 | 12:39 PM
MBSebas87's Avatar
C300 Sport 4Matic
lol
MBSebas87's Avatar
C300 Sport 4Matic
got the answers i needed..thanks!
Old Jan 27, 2014 | 09:58 AM
robnyc's Avatar
X4M, G80 M3
I agree I've been checking my car's temp this month that's been the coldest 10-30F and notice the car doesn't warm up at all when its idle. But warms up right away as soon as I drive off slowly. No more idling for more, but this is very different compared to my dads 2002 Toyota Avalon and 2007 Toyota Camry those cars warm up idling and i think it hurts those japanese to drive off cold.
Old Jan 27, 2014 | 01:13 PM
JaredP's Avatar
2014 E63 AMG S
I let mine idle for a minute or so, then drive off being very light on the throttle. My V6 will cool down when driving in traffic only when it's below -30C or so.
Old Jan 27, 2014 | 01:25 PM
AMG Boost's Avatar
2010 C63 P30
I idle my cars for 5-10 minutes before I drive in winter time. My reasoning for this is that in the cold weather the oil is very very thick, like honey. I idle it to warm up the oil and distribute it through the engine properly. Idleing is the lowest RPM the engine will spin at, so therefore this is where the least damage should be caused by the thick oil. If I was to drive off after 30seconds I would be doing theoretically more damage because I am increasing the RPMs....
Just my thinking on that.
Here is a cool video showing what extreme temperatures will do to engine oil:
Old Jan 27, 2014 | 02:40 PM
Quadcammer's Avatar
96 and 08 911 turbos
Cold oil flow test - YouTube
First, yes, negative 32C is -26 degrees farenheit and thats very cold. But if you note, the 0w oil flows pretty well. Hence the 0w-40 most people run in their MB. If you regularly see these temperatures, you likely could benefit from a block heater.
2nd, placing the engine under load, even at fairly low rpms, ensures that it heats up quicker and the oil thins out. By idling, you just prolong the period of time that the engine runs with cold oil.
3, most critical engine parts, such as the cams, main/rod bearings have an oil film, even after sitting for quite some time. this, combined with the fairly quick flowing 0w oil, means you should be just fine to start it, idle for about 30 seconds, and drive away.
lastly, this wastes less gas and also warms up your transmission and differential oil.
Old Jan 27, 2014 | 02:51 PM
Quadcammer's Avatar
m1 0w-40 is the third from the right when flipped over. Even at -11F it flows pretty quickly. keep in mind this is only gravity not pressure fed.
Old Jan 27, 2014 | 03:50 PM
Sportstick's Avatar
Another round of ICE
Paging Dr. Ruck.....Dr. Ruck to the forum thread, please!
Old Jan 28, 2014 | 08:58 AM
KCaudell's Avatar
2016 C300 4Matic Sport
Thanks for the oil flow videos at cold temperatures. Cool. It makes an important point. In cars that I've had that have oil temperature gauges, I've found that cars don't come up to full operating temperature until after about 15 highway miles. It takes longer than you'd think. MDMercedesGuy is spot on, coolant temperature is not a good judge of when you can drive more "aggressively".
I believe the best thing you can do for your car is drive it everyday. Be gentle until it's up to temperature (± 15 miles).
My 2¢!
