C63 Tire Size Question
Hi MBWorld, I would like to ask if it is possible to use 245/40 tires on the rear C63 wheels (9x18 ET54)? I believe the OEM Stock tire size for the rears are 255/35.
In addition, would there also be an issue of using 225/45 in the front wheels (8x18 ET45) vs the 235/40 OEM?
Will there be any problems for such set up? Any pros and cons of doing this?
It would be used on a 2009 Bone Stock C300 Sport.
I really have no idea on wheel set up, so forgive me for my ignorance.
Thank you so much for reading.
James
James
Factory ordered 2012 MB C350 w/Dynamic Handling Package
C63 original front & rear
235/40-18
255/35-18
on non-AMG w204 the front size is
225/40-18
For future inquiries...the recommended delta in tire size should not exceed +/- 2%
With that in mind you can use this online tool to do the math for you...
http://www.miata.net/garage/tirecalc.html
Comparing the original rear tire size to what you are asking you get a difference of 2.8%
If you are unsure about the pros & cons, I suggest you stick to stock tire sizes.
235/40-18
255/35-18
225/40-18
