halogen bulb replacement question
Old Feb 7, 2014 | 09:00 PM
makeinu0's Avatar
2012 C250 Sport
Sorry, been trying to replace one of the halogen bulb on the low beam.
I searched, but all I find are DIYs on pre-facelift models, where the bulb came straight out of the housing once a black plastic piece was removed. The bulb in my car comes like how its in the pic, and I tried pulling on it but won't come out.
Any tool required?
thanks
Old Feb 8, 2014 | 12:07 PM
makeinu0's Avatar
2012 C250 Sport
Really? no one replaced the bulbs?
Old Feb 8, 2014 | 12:14 PM
nelson g's Avatar
C300 4matic
Did you check your owners manual because that is were I found the information on how to change the bulb in my C300. Just trying to help.
Nelson
Old Feb 8, 2014 | 02:25 PM
Leenseen's Avatar
C350 & R350
No tool required... Grab the bulb using a tissue or cloth and pull it away from the housing. It will come apart without much force.
Old Feb 8, 2014 | 05:53 PM
makeinu0's Avatar
2012 C250 Sport
Nelson
Hey Nelson, thanks for the reply.
I did indeed check the manual (the first place to look), but it only the steps to remove the plastic piece from the housing.
Old Feb 8, 2014 | 05:55 PM
makeinu0's Avatar
2012 C250 Sport
Leenseen thanks for the reply.
I did try to pull that thing off with good amount of force, but it did not come off. I will try again!
Old Feb 8, 2014 | 07:13 PM
tonyteetime's Avatar
2013 C300 sport 4matic
Try to wiggle it a bit to loosen up dirt or residue that may have caked in the tropical hot weather. Use a cloth or hand towel to prevent cuts to your hand in case the bulb break while pulling it out.
Old Feb 8, 2014 | 08:06 PM
makeinu0's Avatar
2012 C250 Sport
Thanks, I just inserted a minus driver in between the casing and bulb and slowly pulled it out. It took some force to do this.
Thanks for all the replies!
