Whell balancing 17 * 7 ,5 j ET 47
W204 c220 Avant-garde Exec
HI , can somebody tell me the exact weight lbs on each whell .
I got OEM mercedes factory rims
Can it be différent front & rear ?
advance thanks
advance thanks
I need to Know whats the weight added on wheels , i feel like my rear arent well balanced , any idéa Of how many grams at Max per wheel
Only a wheel balance machine will determine how much weight is needed. when ever you dismount and mount a tire on a wheel it will need to be balanced. A specific wheel doesn't require a specific amount of weight. Also by the way they did a ****ty job on balancing your tires, they should of used stick on weights.
MAX 35 grms on a side so a wheel shouldnt have more than 70 grms , dont remove the original grms, aftermarket grms looks ugly .
