how to program your aftermarket oem tpms.
Old Apr 4, 2014 | 04:23 PM
xzotik1's Avatar
C300 AMG SPORT
I thought I would share this find. My new wheels are on the way and I sold my MB wheels with the tpms on them. I will order these off eBay.
Description Relearn (Set of 4) 2007-2012 Mercedes Benz C Class - ITM 08003 433MHz TPMS Sensor
  • ITM Uni-sensor: The Ultimate Universal Solution
  • Original equipment replacement sensor
  • Built in original equipment components
  • Adjustable valve stem
  • Includes TPMS sensor, sensor screw, valve stem, rubber washer, valve core assembly, sensor nut, valve cap
Technical Specs
  • Battery Life: 5+ years
  • Storage Temperature:-40C to +125C
  • Operating Temperature: -40C to +125C
  • Operating Humidity: 90%
  • Operating Frequency: 315 MHZ & 433.92MHZ
  • Pressure Monitoring Range: 0 to 60 psi (450kpa)
  • Pressure Reading Accuracy: ±1psi (±7kpa) at normal pressure range, 0 to 50 units
  • Temperature Reading Accuracy: ±4 at -20 to 70 units
  • G sensor Reading Accuracy: ±18.75% at -40C to 90C
  • Transmission Power: typical 8 dBm (both 315MHZ & 433MHZ)
  • Battery: 3.0V
  • Sensor Weight: 35g (1.23oz)
RESET Air Pressure
1. Inflate all tires to pressure listed on tire placard.
2. Turn ignition to ON position (engine off).
3. Press forward/back button on steering wheel until trip and odometer are displayed.
4. Press UP/DOWN button until tire inflation pressure monitor is displayed
5. Hold down reset button (located on instrument cluster) until MONITOR CURRENT TIRE PRESSURE? Is displayed.
6. Press + button TIRE PRESS, MONITOR ACTIVATED-PRESS. DISPLAY AFTER DRIVING A FEW MINS. is displayed.
7. If REACTIVATE-TIRE PRESS. MONITOR! Appears, repeat relearn procedure.
8. If CHECK TIRES! appears, indicates tire pressure too low, adjust pressures accordingly.
Relearn New Sensor Ids
Ensure all tires are inflated to the pressure listed on the tire placard. Vehicle must be driven for at least 10 minutes, while maintaining speed above 15 mph in order for system to learn new sensor IDs. If spare tire sensor ID is being programmed, a properly formatted scan tool is necessary.
Original Equipment Manufacturer (OEM) Part #
  • 003 540 0217
Old Aug 10, 2015 | 04:29 PM
Bimmer777's Avatar
2010 GL550, 2013 C63
Bump. Have you had any trouble with these since installing?
Old Aug 11, 2015 | 01:05 PM
BenzAMX's Avatar
2011 C300 4Matic
Thumbs up!
