Heater/AC Blower Motor Removal C300 -2008
Old Apr 20, 2014 | 11:26 AM
Buzzie8's Avatar
s430
I have the cover off the passenger side area and have the blower motor exposed. Unlike older models where there are a few spline screws to remove the older model C300 blower motors, mine has a an arrow where it looks like there is a latch of some sort holding the blower motor in. I cannot seem to budge it however. Does anyone know the process for removing this years blower motor located under the passenger side dash? I have attached a photo of the blower motor with the arrow imprinted on the plastic molding of the motor.
Attached Thumbnails Heater/AC Blower Motor Removal C300 -2008-blower-motor-photo.jpg
Old Apr 20, 2014 | 12:41 PM
Buzzie8's Avatar
s430
Just figured it out. After disconnecting all wiring harnesses. Pull down on tab with arrow on it just a bit twist motor about 1" clockwise. The pull down on motor. (Motor will still be a bit snug I gave it a good pull and it popped out. (Hopefully I did not break any plastic in the housing).
Old Apr 23, 2014 | 06:21 PM
delsole's Avatar
2010 c300 4matic
Hey bud,
Was the motor making a whistling noise when turned on? Just wondering if you bought a new one to replace and if you did, how difficult was it/how much did it cost you?
Old Apr 23, 2014 | 06:28 PM
Buzzie8's Avatar
s430
Originally Posted by delsole
Hey bud,
It was making weird noises then stopped working a few times. I took the cover off the battery and reached into the top side of the blower and turned it with my fingers to get it going a few times. After a few months, it stopped all together. I knew it was the motor. I just received the new one today and will install this weekend. Around $90 on Amazon. Original Behr motor or $150 on other sites, but I don't care because I hate this car. It's a piece of junk. The hardest part so far was removing the cover to the motor above the passenger foot area (under passenger dash). After removing three screws, there is a hook of some sort that keeps cover up. I broke it off by accident. German engineering cluster F. Hope this helps.
Old Apr 23, 2014 | 06:46 PM
delsole's Avatar
2010 c300 4matic
Lmao yea these cars are a pain in the *** to try and repair something. Mine is making a whistling sound but still works. I only use the heat or a/c in extreme circumstances lol I won't fix it until it goes. Thanks for the reply
Old Dec 10, 2014 | 12:46 PM
Jagga's Avatar
2009 C230 4MATIC
Thanks alot Buzzie8 , replaced on my 2009 C230 following steps you mentioned. new TYC working perfect !!
Old Dec 4, 2015 | 08:59 PM
tetobasha's Avatar
2016 C300
I'm hearing noise from the vent with speed over 40 miles/hr and AC/heat OFF... Any idea what that could be? it sounds like a fan but again my AC is OFF. thoughts?
