Old 06-10-2015, 12:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY - FL steering wheel swap
Old 03-12-2019, 07:54 PM
  #326
ketur52's Avatar
E CLASSE A207
Hello I have a problem. After installed my new steering wheel the horn dont stop !
Finally after several tests the horn stop but I think its the fuse or anything like this because now , horn dont work. Other buttons work perfeclty.
Did you have an idea ?
thanks
Old 03-21-2019, 09:04 PM
  #327
Nicholi2007's Avatar
2009 C350
Finally!!!
I finally got the son of a ***** hex bolt out. It took an air gun!
I also bought the column combination swifch. It’s quieter and much smoother when the turn cancels. It feels like a new car. I’m very happy with this mod!
Old 03-25-2019, 03:11 PM
  #328
jafrush's Avatar
2014 C 250
Just completed the wheel upgrade myself in my 14 C250 Sport, but went from facelift wheel to facelift wheel with paddles. Love the paddles, makes you wonder why Mercedes didn't include them from the get-go. Easy install, took all of about 15 minutes.
Anyone looking for a facelift wheel without paddles? Ive got a spare now haha.
Old 03-27-2019, 12:37 AM
  #329
henry666's Avatar
Mercedes Benz C280 2009
Gonna do further steering wheel retrofit.
Found this on ebay with arrow keys,
Buyer said it is for CL 217 , CLS W218 , CLA 117 , GL , GLA 156 , GLS , W292 ...
Will it work ?
It has different paddle shifters, and it is quite expensive.
AMG steering
Old 03-28-2019, 07:39 AM
  #330
Knightmare69's Avatar
2010 C200 CGI
How much and would you be willing to ship internationally? It's the flat bottom?
Old 03-28-2019, 10:11 AM
  #331
jafrush's Avatar
2014 C 250
Yeah, flat bottom. Can ship internationally through work, but it can be expensive.
Old 03-28-2019, 11:49 PM
  #332
2010 C200 CGI
Lemme know how much you want plus shipping cost and I'll see. I've already got the A45 with suede but the flappers do nothing on my 5g 277.6 transmission.
Old 04-13-2019, 12:12 PM
  #333
2009 C350
So after about 6 months or so, my A45 steering wheel is finally installed. I bought the wheel and airbag locally and the facelifted clockspring from Chris the Swede.
Had some shipping issues in the beginning as the package was flagged at customs. Second time around using regular postal the package arrived with no issues.
When I originally went to install the clockspring everything worked until I turned the wheel left. After discussing it with Chris, it was decided the clockspring needed to be zero'd out. So after a few weeks, I finally took my car into a local shop that had the hardware to check the angle. Sure enough, the clockspring was off by alot. Luckily, I never turned the wheel too fast or violently so I was able to not break anything inside. Zero'd out the clockspring and installed the wheel and everything is working with the exception of the paddle shifters, I don't think my car is capable of utilizing them so I need to see if I can find a metal shop to make me some paddle deletes.
Can you explain the procedure for "zero out the clockspring' ? Is this an install issue or software related? A week or so after installing wheel, I get ESP, Brake (ABS) errors.
Old 04-13-2019, 12:24 PM
  #334
2009 C350
[QUOTE=henry666;7470870]You have scan tool, so no need to disconnect car battery, and airbag won't expose during plug in.
First remove car key and remove column,
install just the new column, (not install steering wheel)
insert key turn to position 1,
test turn signal and wiper switch !
use tool read angle sensor live data, see if you can get angle reading.... <-- most important!
I have tried some wrong column, turn signal and wiper also work.
if you done this, we can move on.
[/QUTE]
When I go into a left turn, I hear two clicks. Once I compete the turn the turn signal cancels. That does not seem normal. Thoughts?
I have ESP and Brake Errors 1 week later.
Old 04-15-2019, 11:02 AM
  #335
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I have a FL heel flat bottom with paddles with red stitching for sale
Old 04-19-2019, 12:41 PM
  #336
2009 C350
Originally Posted by AussieC250
That red tab in the centre is to make sure the alignment stays correct, so just remove it.
If you buy a used one, how do you ensure it's centered correctly?
I have ESP and Brake on 1 week after upgrading.
When I use turn signal, I hear two slight clicks and into full turn it cancels. I have a feeling something is WRONG.
Old 04-21-2019, 01:38 PM
  #337
2009 C350
Unhappy Broken Or Misaligned ClockSpring - SOS!
I upgraded to the 2013 clock spring on my 2009 C350.
When the turn signal blinking, as I start to turn left I hear a click and then another into the turn.
When I don't use the turn signal there are no clicking sounds going into turns.
All functions work. I have a steering Malfunction and Brake on dash. Scanned shows ESP internal fault.
Is that clock spring just misaligned or broken? Can Anyone Help?
Old 04-22-2019, 02:55 PM
  #338
olik's Avatar
c300 2013
Brand new member here, for everyone who swapped their steering wheel is the paddle shifter working or it's just sitting there?
Thank you!
Old 05-01-2019, 11:15 PM
  #339
henry666's Avatar
Thank you!
Normally it should work.
But some will need coding, it depends.
Old 05-01-2019, 11:24 PM
  #340
henry666's Avatar
Wink new steering wheel
I have got the new AMG performance steering wheel,
it is full alcantara wrapped with big AMG shift paddles.
All buttons and paddles are working, buttons light up,
hand feeling is so great !
Old 07-13-2019, 08:06 AM
  #341
henry666's Avatar
Angle sensor error reset
Probably it is a bit old to talk about it.
In case there is ESP fault that due to steering angle sensor error,
Steering angle sensor has internal fault...
Here are the steps can reset it.
1.
Take out the string connector, you will see the mainboard as photo.
Then take out the IR reflector.
Simply use a 2mm flat screw driver to pull both side gently, don't break it.
2.
take out the copper rotor disc...
be careful don't bend it!
3.
Use T10 unscrew it, then take Out the White gearwheel,
then wait for 10sec.
4.
On that white gearwheel, there is a hole on it.
Make sure it is pointing up, then put it back on the original location.
!! don't just put it back then turn the White wheel until that hole pointing up, this will cause of angle sensor error.
5.
install back the copper disc.
Make sure the middle teeth(red circle) is pointing to the hole on the White gearwheel.
6. Put back the IR reflector, install back the spring connector, now ready to test.
7. Install it back to your car, use a diagnose tool to read data steam of SCM (steering column module),
check that the angle reading is correct and it will change when you turn the spring.
8. If angle reading are correct, install back steering wheel and airbag.
Insert car key turn to position one, or press start button once if you have keyless.
Clear ALL fault codes in your car, especially in: ABR, SRS, IC, SCM.
That should fix the angle sensor internal error.
I have been searching around but no body mention about the angle sensor.
Old 08-19-2019, 04:58 PM
  #342
Hojo76c300's Avatar
2008 and 2016 C300
08 sport 4matic c300
Will that steering fit a 08 sport 4matic c300
Old 08-24-2019, 02:06 PM
  #343
Ezzedr's Avatar
C350 sport 2008
I would like to know if you had to change the column in order the paddle shifts work. I own the same steering wheel with the red stitchin but my column is different. Everything works on the steering but not the paddle shift.
Thanks in advance.
Old 08-24-2019, 03:54 PM
  #344
Ezzedr's Avatar
C350 sport 2008
I was trying to contact Chris but I couldnt.
I have installed this steering wheel and this column (clock string). Everything works (buttons, lights, etc) but the paddles shifts don't. As I was reading down all your replies I am thinking about ordering the A212 900 29 24 that a mate bought. But I want first that whoever solved this problem confirm this is the way to solve this problem.
Extra info: Don't know if this could help, but there's a little red man sitting in front of a red ball in my cluster. I think it's an airbag error.
A204 460 4503 3D16
Old 08-25-2019, 04:03 AM
  #345
Ezzedr's Avatar
C350 sport 2008
I think the problem is my clock spring, I think that's why my paddle shifts don't work. This guy has the same steering wheel I own, but the clock spring is different and for him with that one, paddle shift works...
Old 09-17-2019, 04:04 PM
  #346
moegibike's Avatar
w208 w209
2014 steering wheel connector ?
got this out of the new steering wheel , need the pinouts , cables are all 3 black . what is + ? wat side is - ? wat side is data cable ? somebody know?
pin say nr 6 and 5 and 4 are connected in this 6 pin connector
Old 09-18-2019, 12:57 AM
  #347
henry666's Avatar
I don't know the actual pinout,+ - signal etc.
But yes only 3 pins is used.
If you have Distronic then it uses 5pins, but you need Steering column with 5pins socket and Steering wheel with 5pins plug.
Old 09-18-2019, 01:19 AM
  #348
henry666's Avatar
A204 460 4503 3D16
Do you have -D+ ?
Old 09-18-2019, 02:20 PM
  #349
moegibike's Avatar
w208 w209
yes i have -D+, pic are from a 2014 steeringwheel , want to make it in a w209 , its already into there with other connectors , and some adapterplate for sensor . it fit .. only concern about adding the wrong cables onto the connector like in the pic , the old w209 is also 3 pin output , but cables are colord , red/black/wihte
Old 06-30-2020, 08:46 PM
  #350
aznmode's Avatar
2010 c300
Anyone know where to get updated airbags for 2012-2014 steering wheel?
Quick Reply: DIY - FL steering wheel swap
