Headlight Condensation? Assistance Needed
Old Jun 21, 2014 | 08:44 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
So I bought brand new headlights and pretty much from the beginning there was some fogging in the lens. I have had these for about 6 months
Is this normal due to the heat from the bulb? Any assistance is appreciated.
Attached Thumbnails Headlight Condensation? Assistance Needed-w204xenonheadlight.jpg
Old Jun 21, 2014 | 10:50 PM
odus's Avatar
C250
I don't see anything wrong in that picture??
Old Jun 22, 2014 | 01:30 AM
Here is the back cover. The seal looks pretty thin!
Is this normal? does not seem so.
Old Jun 22, 2014 | 02:53 AM
chrisdean's Avatar
W205 C200 AMG Line Premium
Yes, it's normal, it's mentioned in the handbook.
Old Jun 22, 2014 | 09:43 AM
odus's Avatar
C250
It doesn't look like condensation at all. All Lights do that My acura witch has some of the Best projectors out there does that on the front of the lens when lights are on.
Old Jun 22, 2014 | 01:14 PM
tofu-'s Avatar
c63, 335i
that's not condenstation. you're just seeing dust inside or rock chips outside
Old Jun 22, 2014 | 02:08 PM
95Sinned420's Avatar
2016 S550
Unless he's talking about the top part by the eyebrow area? Looks a bit "fogged" there..
The white circle in front of the light is just light hitting the surface, the specks are tiny rock chips or surface abrasions.
Typically, if you have condensation issues in any headlight assembly, moisture has gotten into your headlight housing. This may be when you installed new bulbs, or there is a leak, etc. To get rid of the moisture in the air that is inside the headlight, you need to heat it up, this can be done by turning on the lights for a period of time, you open the covers to let the moisture evaporate out, rather than collect on the lenses and become condensation. Once the moisture is evaporated out, you put back the covers and you shouldn't have that issue anymore. If you do, there is probably another leak somewhere...
