Help! Tire rubbing and caused Front right Fender liner is cracked
whenever run over bumpy road , front tires hitting the fender liner "inner upper side" "rear is fine"
now i see there is a cracked line on the front right fender liner ..its not too serious thou
and i found that its not that expensive to replace the fender liner
probably $100ish usd each
but the thing is.. this parts is really important, cuz it helps preventing water going into the eletrical parts...
so how do i know when do i need to replace it?
and the tech told me that there is nothing i can do to avoid the tire rubbing , unless if i install a stiffer suspension such as coilovers.. i know i wont do it..
thankssss
You need to resolve the real problem of why you're rubbing to begin with. Unless your shock is blown, it's not a "soft suspension" problem. What wheel/tire setup are you running, including the offset?
