have to replace center vent assembly - COMAND up/down and hazard/ESP buttons removal?
Subscribe
Sep 13, 2014 | 10:46 PM
i had a rattle/tick in the center vent assembly and used readily-available write ups to remove it and inspect behind. however, when pulling on the two homemade tools used to pull out the vent section, one tool popped out and scratched the surround (lesson learned? PUT ELECTRICAL OR MASKING TAPE ON ANY SURFACES NEAR THOSE OBLONG HOLES IF REMOVING!!!)
so, i want to replace the assembly with a brand new one. however, i need to remove the switches from the old center vent assembly.
to they come out easily? if it's finicky or might cause problems and more broken parts, i might not want to mess with it.
any experienced comments are definitely appreciated!
thanks.
Reply 0
Sep 25, 2014 | 12:04 AM
so, to update this...
i removed the buttons today and re-installed them into a new assembly. simple as heck. a small flat long flat head did the trick. it helped to see what the bare vent assembly looked like, so i could see how the buttons snapped in.
Reply 0
May 21, 2016 | 09:41 AM
Can you point me to where you found that write-up? I need to remove my center vent assembly to replace it, the sliders are broken.
Reply 0
May 21, 2016 | 10:10 AM
Quote: Can you point me to where you found that write-up? I need to remove my center vent assembly to replace it, the sliders are broken.
there are a bunch. http://www.pelicanparts.com/techarti...nt_Removal.htm
Reply 0
Subscribe
Currently Active Users (1)
