Passenger eyelid error
Old Oct 23, 2014 | 05:31 AM
AK-Benz's Avatar
2010 C300 4MATIC Sport
I've been using LEDs for the eyelids as well the side markers. Until a few months ago Ive replaced the LEDs to a new upgraded model and started to get an error for the one eyelid on the passenger side.
My troubleshooting:
-checked wires to socket, not stripped or loose. Looks solid
-swapped LEDs, good LED
-placed OEM bulb, does not illuminate
-turned car on and off then turned lights on, no illumination on the out socket
I've searched for hours on this issue and could not find another solution to try. Any suggestions would be greatly appreciated! Thanks!
Old Oct 23, 2014 | 05:36 AM
a1rh3adsz's Avatar
'06 mz3, '12 R6, '09 W204, '02 A4 B6, '14 IS350
I had try to put AZN leds on my eyelids also. it works and all but sometimes it does not light up on one side cause of the metal contact. so i gave up and return to stock. and my stock bulbs did not work either. not sure if it help but i guess i used my bare hands to take out the stock bulbs so i think it gave. i order new oem bulbs and put them in and BAM it works.
Old Oct 23, 2014 | 06:06 AM
black lavender's Avatar
R8, C63, C300
Any info on this would help me as well.
My passenger side inner bulb does not work and has an error.
Old Oct 23, 2014 | 09:31 AM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
Check fuse box?
Old Oct 23, 2014 | 11:55 PM
AK-Benz's Avatar
I kept all my OEM bulbs for backups. I immediately swapped them for LEDs, now rocking AZNs (much better light and quality, in my opinion). I should clean the socket with some alcohol. Might not even have a good contact.
Sorry, I forgot to mentioned that I did check all the fuses but since its the one bulb on the passenger side (inner one to be more precise) I doubt its a blown fuse.
