C200 Cgi - PiggyBack
Series
Optimized approx
Difference
power kW / PS
135 KW / 184 PS
170 KW / 231 PS
35 KW / 47 PS
torque
270 NM
312 NM
42 NM
Note: The Evox - go on 4 Sensors ... Boost pressure Sensor, Throttle valve switch, Intake Mainfold pressure Sensor, Camshaft position Sensor
But I don’t have any reference compere this manufacture to kleemann or any other.. So I will need you opinions in what will be the best option….
More importantly, it monitors all temps and pressures (has full access to the ECu wiring loom) and will shut down the performance mapping if anything goes outside of safe parameters. To me, that peace of mind is worth every cent
I know of people using their power pedal and they love it. I think it is comparable to sprint booster and VR tunes item so it is really up to what brand you want to go with there.
Their AutoFlash intrigues me, I am definitely going to try it when I have the spare funds. Speeding up our gear shift changes and getting rid of the gear engagement delay will probably be the best performance upgrade you could do
