2023 C300 reverse camera
Old Dec 6, 2014 | 12:24 PM
Jillmark99's Avatar
2013 C300
2013 C300 reverse camera
Hi all. First post for me here. I have a 2013 C300 with command. I am adding a rear view camera but can't get it to work. I have read a lot about how to do it here on the forums and have done everything step by step but only get a black screen when the car is put into reverse. I entered the hidden menu and turned on the rear camera. I connected the FAKRA connector to my command unit, ran a cable to the trunk and hooked up the camera to 12volts (not the reverse light). When I put the car in reverse I get a black screen and "check surroundings" displayed but no picture. I have power to the camera and I've tried 4 different cameras. Is there something I'm missing here? Is there something else that needs to be enabled as well? Your help would be appreciated. This is very frustrating. It's a Canadian car. I can't remember the model of comand but it's the one that has the SD card slot in the dash.
Old Dec 6, 2014 | 02:58 PM
chrisdean's Avatar
W205 C200 AMG Line Premium
Find the reverse camera option in the display settings. The basic menu on the COMAND screen, it's in there somewhere, not the hidden menu but the one open to anyone. If it still doesn't work try and experiment with the different camera types in the hidden menu.
Old Dec 6, 2014 | 03:46 PM
Doa's Avatar
Doa
W205
the NTG4 system does't just support any camera so maybe you have bad luck on that part
Old Dec 6, 2014 | 03:56 PM
chrisdean's Avatar
2013 + SD card slot = NTG 4.5.
Old Dec 6, 2014 | 08:38 PM
Doa's Avatar
Doa
W205
NTG4 or NTG4.5 is the same thing for that matter...
its called 4.5 for a reason
Old Dec 10, 2014 | 08:59 PM
charles.soori's Avatar
2014 ml63 and 2014 ml350 bluetec
I'm sure your not powering the camera properly. or maybe your FAKRA cable is not good
Old Dec 10, 2014 | 09:33 PM
Jillmark99's Avatar
2013 C300
The camera has 12 volts all the time the car is on.
Bad FAKRA is possible I guess. That is the only part that I don't have a spare that I can check with another. I've tried multiple cameras and multiple cables from the FAKRA to the camera and multiple camera settings.
This is very frustrating for a simple job.
Old Dec 10, 2014 | 09:36 PM
what part of Canada are you from? If your local i can try to check with my FAKRA cable and i should have some spare ones as well.
Old Dec 10, 2014 | 09:37 PM
Jillmark99's Avatar
2013 C300
Southwestern Ontario.
Old Dec 10, 2014 | 09:46 PM
Your little far from me. But ya i would definitely check the fakra cable.
Old Dec 11, 2014 | 01:15 AM
handyman762's Avatar
2011 W204 Avantgarde bussiness edition
do you have 2 ports on the back? in that case you need the left one (looking from behind)
Old Dec 11, 2014 | 04:09 AM
Binhly101's Avatar
2021 C300 4matic
Correct me if I'm wrong but aren't 2010 and later models already pre wired for a reverse camera? And if it is, it should be almost plug and play since you've turned the feature on in engineering mode.
Old Dec 11, 2014 | 09:25 PM
Jillmark99's Avatar
2013 C300
My Comand only had one green port on the back that wasn't being used.
I'm not sure about pre wiring post 2010. I didn't see a video cable or power connection in the underside of the trunk lid.
Old Dec 12, 2014 | 01:43 AM
[QUOTE=Jillmark99;6260726]My Comand only had one green port on the back that wasn't being used.
It needs the left one for de cam, if that portis full allready change that one the right side
Old Dec 12, 2014 | 09:46 PM
Jillmark99's Avatar
2013 C300
This is not my actual command head unit but this is what the back of mine looks like. I connected into the green port.
Old Dec 15, 2014 | 07:27 AM
OK, that's an older command. Mine has 2 extra green ports on the bottem.
Did you enable de aux button in de hidden menu?
Old Dec 15, 2014 | 08:29 AM
Jillmark99's Avatar
2013 C300
Yes I did try enabling Aux as well. It made no difference.
Old Mar 21, 2015 | 05:13 PM
Jillmark99's Avatar
2013 C300
What are the odds of the FAKRA cable being bad? Has anyone else experienced a bad FAKRA cable?
I bought mine from MidCity.
I walked away from this for a few months because I've been very busy but I would like to get this working now that I have some free time.
Thanks in advance.
