Washer Fluid Leak
I seem to have a leak coming from the window washer fluid reservoir. Is there anything simple to check such as a hose or anything like that before I take anything apart to try to fix the issue. I do not think that it was the cause of a rock or something like that because it seems to be too compact in that area for a rock to make it through the fog light grill and do damage to the reservoir. My thinking was some hose might of came loose. Any thoughts on that guys?
I had to take the front/left wheel off and removed the liner to access the reservoir. I found that the washer pump rubber O-ring wasn't keeping the fluid inside of the reservoir (the fluid went through the O-ring). I replaced the washer pump and O-ring. No more leaks.
I think that's what you need to do that. The pump can be purchased at AutoZone for $26 and the O-ring from Mercedes dealer for about a dollar.
Hope it helps...and by the way, I'm a half Croatian!
Haha I just saw this post.. 1/2 Croatian, thats interesting. I do not run into too many of my fellow Croats often.
As far as the leak. I still have not had a chance to check it out but I did speak to my service adviser and he instructed me towards the same thing since it leaks enough to set off the sensor. Do I need to replace the pump itself or just the O-Ring to fix my issue or both?
