P0128 Code
Old Feb 26, 2015 | 02:56 PM
neek's Avatar
C300
P0128 Code
Engine light came on with a code of P0128. After doing some research, usually it can cause over heating on your engine and no heater.
Weird part is, the tempature is steady at 80/85 and have heater working. What can possible be wrong?
I was told to clear which I did, after a day it came back. If any stupid reason, I'm based in Canada and it's been -20ish down here.
I'm planning on taking it to the dealer but this might be a DIY thing and you guys can probably help out.
Old Feb 27, 2015 | 04:26 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
https://mbworld.org/forums/c-class-w...mperature.html
Looks as if your thermostat has failed open. If so better have it replaced sooner rather than later as the lower temp will increase engine wear in the long term.
Old Feb 28, 2015 | 09:02 PM
95_993's Avatar
G63
Agree with above. Thermostat. Just did mine a month ago at 34k miles.
