What gear oil and filter,and engine oil what the best for w204 c200 cdi
Old Mar 11, 2015 | 10:05 PM
roei's Avatar
w204 c200 cdi & ml350 w164
Hello everyone I'm new here and thanks for the help, I want to buy gear oil and filter,and engine oil what the best for w204 c200 cdi 2008
Old Mar 12, 2015 | 05:33 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
You should use the MB approved oil for modern diesels . The MB spec # is 229.51 .
Take a look in your manual & you will be able to confirm this information.
I suggest picking an oil from the list below which is sold at a resonable price in your locality.I have used Mobil one ESP 5w30 to date in Australia.
If you have a particulate filter make sure you use an oil to suit.
MB sheet 229.51 approved oils; low ash long life Mercedes pioneered this new spec for passenger cars with diesel engines with exhaust particulate filters, and gasoline engines, and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Anglomoil RoadMaster 500 API SM 10W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Aral SuperTronic Diesel 229.51 0W-40 LOW SAPS
Bizol New Generation SAE 5W-30 (added 09 July 2007)
Castrol EDGE Formula RS SAE 0W-40 (added 09 July 2007)
Castrol EDGE Turbodiesel SAE 0W-30 (added 09 July 2007)
Castrol Longtec Turbodiesel 0W-30 (229.51)
ELF Solaris LSX 5W-30
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
megol Motorenoel New Generation SAE 5W-30
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 15 May 2006)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from December 2005)
OMV BIXXOL special C3 SAE 5W-30 (added 09 July 2007)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Sunoco Synturo Xenon SAE 5W30 (added 09 July 2007)
Valvoline SynPower MST 5W-30 229.51 (added 01 June 2006)
For the Auto transmission I use Titan ATF 4134 for my 5 speed. MB Specification 236.14
JC
