Convert Alarm Horn to Siren
Old Mar 12, 2015 | 10:50 PM
W57thNY's Avatar
2013 Mercedes-Benz C250, Iridium Silver Metallic; 2001 Mercedes-Benz C240, Brilliant Silver Metallic
On some of the older W204 C's, when you locked/unlocked the doors, the car would beep, the alarm siren was an electronic tone, at some point in model cycle, I believe after the mid-cycle refresh, the chirp was changed to a horn beeps, and the alarm tone became a honking horn. Does anyone know if it's possible to change out the horn for the siren?
Old Jun 4, 2017 | 02:15 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
I was wondering this same thing. Did you ever get an answer or resolution?
Old Jan 19, 2018 | 08:01 PM
mrtomq's Avatar
2012 C250
Same question. I was actually able to get a siren from a W203 located under the front passenger fender. Can I install this instead of the horns?
Old Jan 19, 2018 | 10:17 PM
Silver_Arrows's Avatar
1986 Porsche 911 Coupe, a 2002 CLK320 & 2013 C300
Is there a siren? Trigger the alarm and if the horn sounds instead of a siren then you'll have to rewire the trigger to the siren. I was bothered by the horn when closing the car, so I just turned off the audible tone when locking. Those sirens were problematic because they had an internal battery and when the battery died would cause all sorts of intermittent false alarms.
Old Jan 22, 2018 | 11:38 AM
mrtomq's Avatar
2012 C250
Mine did not come with a siren. It honks when alarm is triggered. In the W203, the siren was under the plastic wheel wells. Does anybody know if this is the same for a W204?
If not, how do I install the siren? I can turn off the audible horn but where do I tap the siren?
