C250 filter
Old Mar 13, 2015 | 10:06 PM
MusicComposer's Avatar
2013 C250
C250 filter
Is an oiled drop in K&N replacement filter okay and safe for the 1.8 T ? I know some cars don't like them. Figured if I have to replace the stock one soon might as well get one that stays clean longer.
Old Mar 14, 2015 | 05:27 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Some have experienced problems with the oil on air cleaners affecting their air flow sensors. Take a look at the Search feature at the top RHS of the 204 page. You will have plenty of hits.
Maintaining a European car requires quite a different mindset . To keep out of trouble it is best to conform to their specifications including oils,coolant,all filters & spares. The forum search feature will give you a lot of information . Royal Purple does not fit the specs.
Make sure for trouble free running your auto gearbox is serviced every 39,000 miles & drain the torque convertor too or flush if has no drain plug. Refill with only MB spec oil.
It is good to find a trusted serviceman who knows European cars.
Good luck & enjoy.
Old Mar 15, 2015 | 06:00 PM
2013 C250
Good luck & enjoy.
Okay, thanks. All noted. I did use the search feature actually, maybe I missed it but a lot of the issues with oil filters turned up threads for the V6 engines.
,thanks
