Odb fault code help I get p2334 and p22e0 power train? C200 cdi w204
P22e0-powertrain
P2334-powertrain ignition coil L primary control circuit high
How can I fix that thanks for the help
I found the info below on http://www.mercedesmedic.com/faultcodes/
P2334 The CAN signals sent from control unit N73(EIS control module) are incomplete.
Could it be the EIS :- Electronic Ignition Switch is causing the problem.Could you have it checked.?
