Where is power steering?
Old Apr 2, 2015 | 11:58 PM
teezbenz's Avatar
2009 C350
I need to add power steering fluid. What brand do you recommend? And where the hell do you put it?! Lol
Old Apr 3, 2015 | 12:34 AM
c300white's Avatar
2008 C300
What model year ? Why do you need to add if you don't know where the reservoir is ? There is a small black tank with cap at the front right of engine as you are looking at it. Check fluid level first ? If it has never been drained and it is >5 years old - you might want to consider going to somewhere like aamco and have them flush it - or use turkey baster to remove as much as you can and refill with dealer fluid or Pentosin chf-11 in green can that you can get at many auto parts stores. Just don't overfill (cap has two marks for hot and warm levels) and don't use Atf that works in bmw and other cars ...
Old Apr 3, 2015 | 12:53 AM
teezbenz's Avatar
2009 C350
You raise a great point. I hear a humming noise any time I do a really tight turn and I know normally that means power steering is low, right?
Old Apr 3, 2015 | 01:02 AM
c300white's Avatar
2008 C300
Could be - check for signs of leaks at hoses that run from the reservoir . If car is 5+ y/o can't hurt to flush fluid ( or cheap method is turkey baster) - just don't overfill. That is $20 quick fix if you are lucky ...
Old Apr 3, 2015 | 02:54 PM
MB@C200K's Avatar
C 200 K
............ - just don't overfill. ...
Why ?
I just add(reason:low level, but no leaks.....7y old car)some fluid & now it is a little overfilled.
Old Apr 3, 2015 | 03:51 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
It expands when hot. A couple of mm overfill should not be of concern.
