18'' rim fit for 2010 C300 4matic Sport
Old Apr 5, 2015 | 10:08 PM
timster998's Avatar
C300 4matic Sport
Hello,
I am new to MBWorld and new to Mercedes. I have 2010 C300 4matic Sport
I have 17'' staggered setup. I want to go to an 18" rim.
Today I bought 4 identical 18" 8Jx18 H2 ET50 rims with 225/40R18 tires. the part number on all 4 rims is A204 401 4102.
I know that usually the rear suppose to be 8.5 width with 54 offset, but would these fit at the rear? Would these 4 wheels work or should I return them?
Thank you
Old Apr 6, 2015 | 10:10 AM
dudeitsmattx's Avatar
2013 C250 Sport
They will work. But they will seem a little more sunk in vs the factory wheels you have on now
Old Apr 6, 2015 | 03:23 PM
nelson g's Avatar
C300 4matic
They will fit and the good part is that you will be able to rotate your wheels which you can't do if you have the 8.5" wide rear wheels. I know because I have the wide rear wheels and the tires wear quickly because you can't rotate them.
Old Apr 6, 2015 | 03:50 PM
timster998's Avatar
C300 4matic Sport
Thank you, I will post pictures when I put them on.
