a little smoke
Old Apr 17, 2015 | 09:03 PM
kodpkd's Avatar
c300, Maserati coupe
a little smoke
2009 c-300 Sport. After engine is warmed up, I open the hood, it has a hot smell, and a little smoke coming from the right side of the engine, from the bottom near the exhaust. Any ideas?
Old Apr 20, 2015 | 04:02 PM
TheRulesLawyer's Avatar
C350
Does it smell sweet? White?
Old Apr 20, 2015 | 04:28 PM
Rocman8's Avatar
E55
oil centrifuge cover is leaking and/or rear camshaft caps. easy fix.
Old Apr 20, 2015 | 06:34 PM
kodpkd's Avatar
I did read the other thread about the oil leak from the cam cap.. I will check it out tomorrow. Not sure if it smells sweet. I can also check the ATF cooler line. Thanks
Old Apr 22, 2015 | 09:07 AM
kodpkd's Avatar
I did find the leak. It is the crankcase vent valve. Just wondering why this starts leaking. If it is a one way valve, maybe the valve gets plugged, then with a little back pressure it starts leaking. Anybody try to unplug this?
