Passenger seat shaking at high speeds?
Old Apr 22, 2015 | 08:27 PM
james158485's Avatar
C300
I have a 2012 C300 and I've noticed that whenever I get to highway speeds the passenger seat begins to shake. It's not just a mild vibration either, you can see it shaking. What could be causing that?
Also, my steering wheel has a very slight vibration to it. I'm not sure if something is wrong or if I'm just used to Lexus LS-like NVH levels.
It was just inspected my the MB dealer and the car has less than 12k miles.
Old Apr 22, 2015 | 10:22 PM
95_993's Avatar
G63
Tires need balanced or you may a bent run from potholes
Old Apr 24, 2015 | 01:56 PM
tgidave's Avatar
C43
Ejecto seato cuzz
Old May 21, 2015 | 11:08 AM
MsMathWiz's Avatar
C300 4Matic Sport
Same thing happens to me. I believe my rear passenger rim was bent when I hot a pothole. I know its not an alignment bc I did that less than 4 weeks ago. Ill let you know by the weekend when I get the rim fixed if it solved the problem.
Old May 21, 2015 | 06:49 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
ya i need to check mine over to from a similar issue but i went over train tracks hard
Old May 22, 2015 | 03:23 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
My passenger seat shakes at high speed. I think it is her knees that cause it .
Old May 22, 2015 | 02:15 PM
MsMathWiz's Avatar
C300 4Matic Sport
I'm at the dealer buying a new tire. The current tire has a huge gauge and bubble. Luckily I didn't crack the rim. I must admit, I did hit the pothole pretty hard. I was actually thinking that in another 10 seconds my pressure sensor would go off and tell me I had no air, but it didn't, so I kept going! So yea....new tire expense coming down my ally.
