Need Front Differential Drain Plug Thread Size
I'm thinking of machining a one-way check valve that would thread into the differential replacing the drain plug and all you would have to do is pump the .6L of fluid back from the drain plug using a fluid dispenser.
If a simpler solution exists already, please give me a link to the thread.
Thanks!
