Oil in the air intake on direct injection engines?
superangrypenguin (02-27-2018)
#52
Agreed that the cats take a beating, but both of these tests are lacking a control.
I think it's pretty universally agreed that the smoke is not caused by the carbon buildup, and that is most likely is the Seafoam that's being combusted and exhausted out. The question that one should have, is what happens to the carbon buildup if, say, water was just put instead. The whole theory behind that is engine = hot, put in something cold, like Seafoam or water (relatively cold), and yes one would expect some carbon to be dislodged. I remember seeing BMW owners add water injection to their cars to help with intake buildup, same principle, similar results.
Still no proof it's the Seafoam that caused the dislodging of some carbon buildup. The second video has a BUNCH of products that he is/was going to test, but he only showed the results of Seafoam.
PS on a balance of probabilities, I do think Seafoam is what cleaned the carbon off of the piston head of the lawnmower!
#54
Yes, water can also be used to "steam clean" the engine, use to be an old school trick where you get a spray bottle and spray it inside the throttle body. Then you let the engine heat soak with the water inside the engine and it steam cleans it, definitely no as much smoke as sea foam, the smoked caused by sea foam is a detergent chemical inside the sea foam I believe.
I like this channel a lot, his experiments are very interesting and informative with results.
#55
https://www.youtube.com/watch?v=2ySSEzqEa_k
The BG44K stuff was OK, but the results weren't stellar when I used it several years ago.
