Tire rubbing fenders pls help
Mercedes-Benz C Class
I bought new set of wheels and tires
Rim Size 19x8.5 35 offset for all sides.
Tire Size 245/35/19
Test drove it while ago, during normal cruising speed, it does not rub,
however if I hit a bump on the road at higher speeds, it rubs a little bit.
I'm sure it is rubbing since the sound can be heard from inside the car.
What should i do??![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I don't want to damage my tires
Tire Size 245/35/19
What should i do??
2014 C200 AMG
Do you have any pics to share?
If I am correct... your offset of 35 means the rims and tyres are quite OUTWARDs from the car body right? What you can do is NOT to use them asap.
My 19 inch set are with 19x8.5 45 and 19x9.5 54 (C63 rims).
I guess the sound is from the front rims?
Tire Size 245/35/19
Tire Size 245/35/19
What should i do??
I still have not taken pics of it, but it is quite an aggressive set up.
I've searched some threads,
Found some options other than not using the wheels... Cause honestly I really like the wheels to work cause I've waited for so long for these wheels.. maybe there are other solutions?
1. rolling the fender
2. grinding off the fender
3. installing a stiff "shock cushion"
4. changing to lower profile tires (235/35/19) - maybe the last option most expensive.
so what do you guys think?
The photo was taken while going down the ramp that is why the rear suspension is compressed.
For the front wheels, I still don't have the photo of the wheels while suspension is compressed
I think grinding off the fender will work?
What do you think?
get your fenders rolled. its the easiest/cheapest option for you
I am running the same off set and think the recommendations others here have stated should work.
1. Roll/pull your fenders
2. Skinnier tire either 225 or 235
I have done both of these
Grinding the fender would help but would also weaken the fender making more prone to dents and becoming misshapen.
I know I'm old, but there's a right way and a wrong way to do something. This all sounds wrong to me. The old saying "Measure twice, cut once".
Ok will roll my fenders
My tires are getting a bit old too, might change them soon.
Tire options:
1. 245/30 r 19
2. 235/35 r 19
3. 235/30 r 19
which one do you think will work?
225 seems to be too narrow? might stretch the tires too much
Cause i also like to have the wider look of the tires.
How about the spring cushion? has anyone tried using those?
235 anything on the front with that offset will ALWAYS rub.
There's very little you can do with a fender roller as the lips are already tucked in pretty aggressively from the factory.
Your biggest problem is that the wheels are absolutely the wrong size for the car. 19s with ET35 offset is just way too aggressive. Not only for rubbing but also tire wear and suspension wear. Not even going to mention the look and feel of stretched 225s on 8.5" wide wheels.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
PS: I run 235/40/18s on the front with the stock offset and my fenders are still rubbing slightly on big potholes.
Rolling your fenders will do little to nothing because there is not much to roll like someone mentioned above. I bet its rubbing against the fender liner or the area where the bumpers meet in the inner fender. Rolling such a small area in the rear will have higher risk of cracking/damaging your paint and there's basically nothing to roll in the front. Getting wheels with the proper offset would be the main solution. BUT if you want to try and MAKE this setup work I think grinding down the inner fender and sanding it down to smooth it + adding camber to the rear will fix your rubbing issue. I think SPC makes a rear camber kit for our cars, also D2 and KSport offer coilovers with fully adjustable pillowball top-mounts (front and rear) which eliminate the need for a camber kit. Obviously the tires will wear faster and unevenly with more negative camber but that's just part of the whole fitment game =]
My front and the rear fender is actually a little deformed now if you look closely. Would not be noticed by other people unless they know what to look for.
Rubbing only happens when I drive fast while there are other people in the car. When there is a straight downward force acting on the 4 wheels. Imagine going down small hill really fast. When you reach the bottom that is when the rubbing happens, the momentum is causing the suspension to compress.
Update:
I installed spring cushions made from polyurethane on all 4 sides of the car. I test drove it with people inside. Definitely a lot of improvement! I drove aggressively, rear does not seem to rub anymore, the fronts still rub a little but it is much better now. The ride is not stiff, on bumps it is basically the same quality ride. I also think the car turns sharper at high speeds. Suspension does not seem to compress too much anymore. Handling is generally better. I still have to test drive it more.
Long term solution:
I also noticed that there is very little to fold on the fenders, so I might just try to grind and smooth out the front fender. Also to change the tires to narrower tires cause i currently run 245/35/19
1 Post
2013 C250 Sport
OP do you have a link to where the spring cushions? When you get time jack the car up in the front and see if there is any marks on the inside of the fender or in the liner near where the fender and bumper meet. I had to cut a small spot out on my liner in that spot for when the shock and spring fully compress. I'm as low as I can go on H&R coils with same front specs as you.
I have 225/35 on my front 8.5" wheel with 35 offset and its not stretched, that is the smallest tire size made to fit 8.5" wheel anything lower then that will start to become a stretched tire. And the fronts have a 1/2'" lip you can roll which does help when running aggressive offset. And there is no different tire wear or suspension wear on my 19's with 35 offset, my alignment is in spec..
This is the spring cushion
Brand is TTC from South Korea
http://thinkthinkcar.com/en/faq.php
Size for a stock C350 is B for the front and D for the rear, but since you upgraded to H&R lowering springs, I rekon your size would be smaller.
Stay away from spring cushions that come from China cause they might disintegrate after a few months. I had a chance to drive the car a little more, it DOES corner better and definitely lesser body roll, I'm quite surprised.
By the way, how much drop do you have front and rear? Was the handling/ride better after upgrading to H&R?
