rebuilding my old headlights
i wanted a new look :smash:
https://cimg0.ibsrv.net/gimg/www.mbw...9015adfcb1.jpg |
Looks cool! How did you do it? :naughty:
That looks good! More details!
that looks awesome , what did you use?
Nice work! can you share more details?
I like it!! Looks very nice!!! Would you care to share the details???
Kind Regards, Vickon |
simple, i made part of the chrome black, removed the eyebrow parking lights and connected a flex led tube and placed it inside with glue that can resist very high and low temps.
you have to modify/demolish some parts though the tube is this: http://www.ebay.com/itm/2PCS-60CM-Flexible-Tube-Guide-Car-LED-Strip-White-DRL-Amber-Turn-Signal-Light-LW-/271908985708?hash=item3f4f09db6c&vxp=mtr |
This means you opened up the headlight? Is it hard to open the headlight?
you just have to heat it up a bit
I figured. Too risky for me I think. I am afraid putting it back, the glue won't be the same and I'll deal with condensation issues.
if you open the back to replace one of the lights you have the same issue no? :)
Originally Posted by Doa
(Post 6529519)
euh? the lens isn't closed or sealed off
if you open one of the caps to replace a bulb and blow in some moist it go's into the lens as well |
Correct, but if you remove the lens and dont get a proper seal, now not just moisture will get in, but heavy water when you wash your car, and that wont evaporate.
A bad seal will be equivalent to not replacing the bulb caps.
True if you open it once to replace the bulbs, moisture could get in. But once you replace that cap, the moisture will evaporate over time. Now if you broke the seal and didn't seal it properly, moisture will always be getting inside. I've had this happen after replacing the glass headlights in older BMWs. It was very annoying. |
the lens is actually open and i never removed or opened up the lens, just the light unit itself
I have opened my car's headlights to paint them (go look at my other threads) and when I put them back together I didn't add any extra glue I just reheated the old glue and put them back together and made sure they were closed completely all around the edges.
(Post 6530437)
