AMG Wheel Change Questions!!!
2010 Mercedes-Benz C350 4Matic
Hello everyone, hope you guys can help me out here:
I have a 18'' AMG wheel cracked and it's too expensive to get a new one. So I am thinking to change the all 4 rims and keep the same tires.
It's 2010 Mercedes C350 4Matic
Current AMG Wheels are:
Front 18*8 ET 50
Rear 18*8.5 ET 54
And the tires I still want to keep are:
Front 225/40R18
Rear 255/35R18
I called the dealership and they said if I want to keep the tires, the new wheels I will buy need to be size "18*8" and "18*8.5" as they were, otherwise, the tire won't fit.
But they have no idea but the ET value, since all the new rims I find can't have 50 or 54.
Anyone can help me out? What ET value I should choose? Thanks,
Front 18*8 ET 50
Rear 18*8.5 ET 54
Front 225/40R18
Rear 255/35R18
But for the ones I am gonna purchase, their offsets are not even close to that. Some of them are like +32, +40 and even some of front ones are larger then the rear ones...... Which is driving me crazy now....
Registered User
1 Post
2010 C300, 2013 C63 AMG
It's the offset value. +50 front and +54 rear are the ones I have now and the same Mercedes recommend.
ET is how far they will stick out. The OEMs are around 50/54, which means they sit inside the wheel well, with the rears sticking out slightly more than the fronts (4mm on each side + .25 inches from the extra wheel diameter). A 32 or 40 will be flush, or maybe even slightly outside the fender (sticking out roughly 2cm more than stock on each side). The tires will fit these wheels, but you need to go call a few tire stores and make sure they won't rub on the inside of the wheel well. Rubbing isn't necessarily a bad thing, but when you have a nice mercedes, it's something you don't want to deal it (gets really annoying and just sounds really cheap). Leave it to the ricers and the big trucks.
How about this?
http://www.1010tires.com/Wheels/DAI+.../Machined+Face
Since I want to keep the tires, this is the best I can find, ET 45 and 42.
And according to here: http://www.wheel-size.com/size/merce...rim-c-350-eudm
Seems OEM Wheel ET could be from 39-58, is that correct?
2010 C350 Sport
My current set of wheels were +40 front and rear, I had to have the rears milled to +45 because they stuck out too much. Now the front and rear are perfectly flush. Anything less than these two offsets will stick out past the fender.
Registered User
1 Post
How about this?
I think a 45 and 42 should be fine, but if you hit a nice pothole taking a good turn I'm sure it would rub a bit, but that could probably happen regardless (and I'd be more worried about your front bumper scraping the pothole. Besides, rubbing tires isn't really bad for the car, it's just irritating if it happens too often). Also, I personally think it would look sweet because I like having the back wheels stick out a bit more!
Also the reason that the dealer knew nothing about ET is because OEM wheels only come in one ET, they don't have different models. You have to do that research on your own and go and order whichever style you want when you're ready, or you can go online and find replicas on ebay or powerwheelspro with the right setup/ET.
OEM ET is from 39-58 yes, but the 39s are found on the actual AMGs, which have a body which is up to like 8" wider than the normal W204s, and have the room/suspension/axle setup for those kinds of wheels that stick out. Like look at the black series, it has 39s I think, but its like a solid 8" wider than the C300.
I might also go for a mechanic to see if he can fix the rim crack for me.
Thanks everyone! Much appreciated!
Hello everyone, hope you guys can help me out here: I have a 18'' AMG wheel cracked and it's too expensive to get a new one. So I am thinking to change the all 4 rims and keep the same tires. It's 2010 Mercedes C350 4Matic Current AMG Wheels are: Front 18*8 ET 50 Rear 18*8.5 ET 54 And the tires I still want to keep are: Front 225/40R18 Rear 255/35R18 I called the dealership and they said if I want to keep the tires, the new wheels I will buy need to be size "18*8" and "18*8.5" as they were, otherwise, the tire won't fit. But they have no idea but the ET value, since all the new rims I find can't have 50 or 54. Anyone can help me out? What ET value I should choose? Thanks,
