CEL on 2013 C250
Old Sep 27, 2015 | 09:07 PM
BrianE's Avatar
2013 C250 Coupe, 2013 C250 Sedan, 2004 Ford SVT Cobra, 2002 Toyota Tacoma 4WD
CEL on 2013 C250
as driving on the interstate when I noticed that when I gave the car a little throttle to pass the car shook like there was a wheel severely out of balance, then the CEL came on. Car had loss of power and shook worse and worse when I gave more throttle. Stopped at a gas station to check the oil level and that was fine and did not appreciate any smoke at all. Turned to car off (to check oil) and when I restarted the car the CEL was off and the car ran fine. Made it to the house, plugged my ODB reader and P0301 (cylinder 1 misfire) came up. Anyone have any problem with this? Car is still under warranty, so she's going to the dealer tomorrow. I'll post what the result is when I get it. Hope the dealership can figure out wtf happened.
Old Sep 27, 2015 | 09:17 PM
Rocman8's Avatar
E55
there were some bad spark plugs on those earlier m271evo engines.
Old Oct 30, 2015 | 10:04 AM
loudbmw's Avatar
17 E300, 17 C300, 14 C250
Similar Problem On My C250
2013 C250 with 18000 miles. Check engine light came on while passing on Interstate. Same code P0301, cylinder 1 misfire. Car ran fine afterwards but check engine light stayed on.
Took it to the dealer, they did a compression check on all 4 cylinders, checked #1 coil and #1 plug, all normal (not replaced).
Dealer then upgraded old M. E. software(???) which they said was not up to date. We will see if this fixes problem.
Old Oct 24, 2023 | 04:29 PM
SL500JD's Avatar
SL500
Hi Justin,
I read your posts and the others, as too have a similar misfire issue on a C203 C180 Kompressor (four cyl). Random and know is does have an O2 issue fault. I done all the basics, new plugs, coils, cleaned connectors, air filter checked, air box etc. Mine runs for 10/15 kms before it looses one cylinder and then when cooled or the next day, runs fine again.
I had radon issues when I purchased this car with the rear lights, which I traced to the rear SAM unit being faulty. This was replaced and all lights worked again, however I lost the lower fog lights two days later. These are fed from the front SAM, so was heading towards a front SAM issue too, for my misfire ! The car is new to me and had some block screen channel drains, which I suspected could have resulted in water ingress to the front SAM. Your post has sent me in the O2 direction, being the cheaper and simpler option first, so greatly appreciate you posting the fix for your car.
many thanks
joe
