Lack of power on 1st gear. Check Engine signal.
w204 C200 2008
Hi,
When I try to dynamically move forward from the 1st gear it doesn’t have the power and then “Check engine” signal is showing. The signal is getting off itself after 1-2days. When my friend plugged the computer to my MB it shows “Camshaft Position Sensor Fault”.
I did a lot of read here and it doesn’t look like Camshaft Position Sensor Fault. Cars starts just fine, it don’t have a noticeable problem with RPM etc.
Maybe someone smarter here will know what may it be? So I wouldn’t have to go to mechanic every 1 month
Lack of power off-idle is hallmark of the broken flap issue. But it throws some specific codes. https://blog.fcpeuro.com/mercedes-be...ymptoms-review
